Where can I get case perimeter studs?
PP is fresh out of 32-mm (exposed) studs. Anyone know where I might find them? I need 6... For a 83.
Old 12-11-2012, 04:08 PM
KTL KTL is offline
Schleprock
KTL's Avatar
If you've got an old cam housing lying around, the exhaust/lower valve cover uses 35mm studs. I have a bunch of them if you'd like some.
Kevin L
'86 Carrera "Larry"
Old 12-12-2012, 10:26 AM
Thanks kindly for the offer, KTL. I was able to locate some at the local air cooled VW race shop. 45mm total length, which is just one or two mm shorter than what I had.
Old 12-13-2012, 03:38 PM
