964 case through-bolt o-rings
somewhere, maybe here, i once heard that some 964 engine cases were cut deeper in the area where the through-bolt o-rings live. never seen it, but now i have one that still leaks after new o-rings. enough to piss a guy off. anyone know about this? it's a '90.
206 637 4071
Old 12-12-2012, 03:28 PM
i searched more and came up with this: Major oil leaking after fresh rebuild! Help!
but i see no listing anywhere, yet, for an optional through-bolt washer that goes deeper into the case. i have it apart again and this seems to be the issue.
206 637 4071
Old 12-12-2012, 05:25 PM
AlfonsoR's Avatar
I wish someone would get around to designing a better seal for these. In the mean time, I'll buy you a beer John....one of these days I'll make it up there. Sorry about your troubles there.
"Simplicity is supreme excellence" - James Watt
Old 12-12-2012, 07:25 PM
I just did a little o-ring research (owning a '90 964 that will eventually need at least a re-seal if not a rebuild gives me a vested interest in seeing this issue solved).
theoringstore.com have a couple of interesting items. First is a broad selection of Viton o-ring cross sections. I'm thinking a thicker ring with the correct ID could be made to work.
Another is these Viton 'back-up rings'. While not metric, they may have a workable size. This would increase the height of the package some, and indeed one could use one inside and one outside the standard ring. I'd never seen these before, but like the idea.
Good luck, please keep us (me!) posted.
'90C4
Old 12-13-2012, 04:23 AM
AlfonsoR's Avatar
My 2006 Dodge has gaskets for the diff cocers that have soft rubber faces with small raised lips and sanwich a steel or SS metal core. The bolt holes have a thicker metal ring so that you don't sqeeze out the rubber. These gaskets are actually re-usable. I've done 2 oil changes and still no leaks.
Why couldn't someone design something similar for our engines?
Old 12-13-2012, 11:05 AM
if the cross-section was oval that would be better. they're 2mm round, so 3mm on the widest part of the oval would allow more crush. for now, i used two 0-rings on each side, a blue one on the inside and a green one on top of it. should be good now. chalk off 2 wasted days. oh well, it's a drop in a bucket of your lifetime. apparently there's a factory bulletin on this.
206 637 4071
Old 12-13-2012, 11:29 AM
Bill Verburg's Avatar
There is a TSB on that, if you need a copy let me know
Bill Verburg
Old 12-13-2012, 12:23 PM
love to have a copy. i have most of the white softcover factory technical bulletin books and i haven't found it yet. if it's in there, just the year and page # will do.
206 637 4071
Old 12-13-2012, 12:48 PM
9107
dated 6/28/91
Bill Verburg
Old 12-13-2012, 01:09 PM
120 HP/Liter is all I ask
Book H, Technical Bulletins Jan - Dec 1991 page 29 affected engine numbers listed.
[IMG][/IMG]
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 12-14-2012, 06:48 AM
thanks for the info. i have that book. back running with two o-rings and so far, no leaks.
206 637 4071
Old 12-15-2012, 05:47 AM
I wish someone would answer my question on why did Porsche installed O rings on the lower though bolts #2,3,4,5 in the 993 RS crankcase and all racing and street crankcases going forward to the GT3?
They sit in a bevel between the case halves around the bolt.
Vibrations?
Anyway, I am doing it on the engine I am building now.
Old 12-15-2012, 06:44 AM
