irl irl is offline
irl's Avatar
Send a message via AIM to irl
How do I remove this
What tool do you use to loosen/tighten this linkage connection bolt on a weber? Its smooth and I can figure out how to grab it to loosen it. I had it posted in the tech forum but i should have tried here i guess.
thks
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-15-2012, 11:47 AM
irl irl is offline
irl's Avatar
Anyone??
79 SC unmolested
25 GTS
Old 12-15-2012, 02:35 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Is it screwed in or pressed in?
If screwed...possibly a strap wrench might work.
For a press in pin...a shaft gripper (like a socket with inward moving grips) and a slide hammer would work.
Bob
Bob Hutson
Old 12-15-2012, 03:45 PM
irl irl is offline
irl's Avatar
Thanks, this is a pretty common part, anybody know this answer.
Old 12-15-2012, 03:48 PM
My first instict would be to not remove it. Do what ever work you are doing with it installed. If I had to remove it I'd grab it with a pair of vise grips, use some scrap aluminum to cushin the jaws so they don't scratch and dent the shaft. To break it loose I'd heat the base with a propane torch. This will expand the magnesium and loosen any locktite.
-Andy
Old 12-16-2012, 11:35 AM
Shaft
Warm up the manifold and it will slide right out, to reinstall heat and a drop of green loctite
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 12-16-2012, 04:05 PM
irl irl is offline
irl's Avatar
Thanks everyone, where could I buy one if I broke it
79 SC unmolested
25 GTS
Old 12-16-2012, 09:43 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Is that a theoretical question or an admission of guilt?
Give PMO a call, as I think this rod is included in their MFI linkage kit? See picture at bottom of page- looks like the shaft is next to the manifold spacers
PMO High Performance Porsche 911 Carburetion
I suspect Richard would have no problem getting you just the shaft alone.
Kevin L
'86 Carrera "Larry"
Old 12-17-2012, 08:58 AM
