SLR SLR is offline
SLR
964 cams fitting to a 3.2
Hi all
1st time on this site, so if I goose it up a bit forgive me.
I have a 1985 Carrera in way good nick, the only thing i have changed was to fit a
Steve wong chip, ye ha. but I'm looking at fitting 964 cams, but have read so many
story
storys,
Has any one here bone that ? and what is the benifits ?. I don't want to flaff about to much , the money thing, I want to fit 8x16's on the rear. as well
thanks Steve
Old 05-08-2012, 12:51 PM
964 cams give more mid-range power; one can feel & measure it.
Your chip will need to be remapped of course.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-08-2012, 02:17 PM
You do not need actual 964 cams. I had my 1979 SC cams re-ground to 964 profile, I assume your Carrera Cams can also be reground. I've also heard that a good header / exhaust will give you the best gains on a Carrera than the chip.
Old 05-11-2012, 12:09 PM
Call 911
dkirk's Avatar
I fitted 964 camshafts to my '88 Carrera 3.2L engine when doing a top-end overhaul. Found a nice set from a reputable eBay seller and paid $450. The cams provide a noticeable performance increase that you can feel...especially above 3800 rpm when the engine really wakes up.
These camshafts have increased duration on both exhaust and intake valve events, plus slightly increased lift. Idle quality is still good, but a little more "lumpy" than the stock 3.2 cams.
The only modification required is to remove the power steering extension stub off of the right-hand camshaft, as shown. My local automotive machine shop did this for $5.
Dave Kirk
My Porsche restoreth my soul.
Old 05-11-2012, 12:40 PM
The re-grind of my SC cams cost me under US$300
Old 05-11-2012, 12:49 PM
Call 911
dkirk's Avatar
One thing that I forgot to mention is that I have a Steve Wong chip that was installed prior to the camshaft swap. I did not have the chip reprogrammed, and find no reason to, due to the way the engine runs throughout the operational speed/load range. Cold and hot starts are perfect, no signs of running rich anywhere, good throttle response, and nice manners. The only change I notice is fuel mileage - before the cam swap I could get 27 mpg (steady state cruising @ 70 mph) which has now dropped to around 25.5 mpg - not a big hit considering the performance increase.
Dave Kirk
Old 05-12-2012, 07:35 AM
Banned
Hi Number1_dog
Where do you have re-grind service, can you recommend one?
Many thanks!
Old 11-20-2012, 07:45 AM
I had my 1979 911SC cams reground by John Dougherty back in 2009.
John@drcamshafts.com or tel# 530-672-2286. He is in Shingle Springs, Ca.
I included a postal money order for full payment and had them back in my hands within a week. I didn't listen to the people complaining about John and he came through.
dog
Old 11-20-2012, 08:13 AM
johnman001's Avatar
How much power would one expect from doing this?
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 11-20-2012, 05:17 PM
a.k.a. G-man
Geronimo '74's Avatar
Same here, chip first then cams.
Are there any benefits to still reprogramming the chip??
Engine runs great as is. Would a remap improve it even more, give more hp?
Old 11-22-2012, 09:34 AM
Anybody have an answer for questions post #9 and #10?
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 11-29-2012, 10:25 AM
French Import
zippy_gg's Avatar
Will the cam regrind cause the car to no longer pass the California smog test?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 11-29-2012, 02:41 PM
Camgrinder says the 964 grind in a 3.2 will pass CA smog
Old 11-29-2012, 09:00 PM
French Import
zippy_gg's Avatar
Thanks TTO! Contemplating the modification as the engine is out.
Gilles & Kathy
Old 11-29-2012, 10:07 PM
gruppe f
mikehinton's Avatar
My '87 3.2 with a Steve Wong chip and 964-grind cams easily passed smog last December, even with the infamous "brown wire" disconnected.
mike
Mike Hinton
'06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine,
'74 914 1.8 Marathon Blue, '64 356C Aubergine
Old 11-30-2012, 09:58 AM
I have Camgrinder reground 3.2 cams and stock chip. Pass CA smog easily. Car 89.
Sold: 1989 3.2 coupe, 112k miles
Old 12-03-2012, 07:50 AM
Arlo911's Avatar
I think remapping would be beneficial when changing cams.
Old 12-08-2012, 01:57 AM
I have the Steve Wong chip on my stock 3.2 Carrera which I am about to re do the top end on.
I'm wondering If I used a 964 profile cam and fitted the higher compression euro P&C's would that effectively negate the use of the chip ?
I have a dansk Pre muf and Dansk sport muf on the car. It strikes me the only sluggish area would be in the 1-2k RPM range. But would the increased torque make up for it ?
Old 01-02-2013, 04:17 AM
"...the only sluggish area would be in the 1-2k RPM range."
Are you planning to turn this into a diesel engine?
I think most would be happy with only a power issue in the 1-2K rpm range.
From many owner comments, the correct Wong chip will only enhance that which you plan to add.
Sherwood
Old 01-03-2013, 01:11 AM
