ID This Mahle Piston, please.
I started tearing down a 911/07 engine today. It should be a 2.2T. It's not.
I find that I have 80mm P/Cs of the Mahle Biral variety. I believe this to be an E piston, yes?
Flip it up and look down on the underside of the crown. There should be some cast identifying numbers/letters.
andy |
There should be a casting number such as 80wxx or some such. We need that number
Bruce |
It's difficult to make out. Looks like:
80V79 CO11 E30 |
On the dome:
2 14 M 129 On the inside of the skirt, on the intake side: 45 9 M |
Bottom picture:
It looks like a 2.0 liter E piston from 69. It's a cast piston and would have used the biral cylinder
Are you sure it's not a 901/07? I think that is a 68L .... It would have the same pistons as the 69E and would be a 2 liter
It's built from parts. It has T cams, 2.0 T heads with casting dates from '67 to '70 and I think it has a CW crankshaft.
I have it listed as a 2.0E, 1969
2.0L has a different casting number and its 9.0CR and the 69E is 9.1CR Bruce Last edited by Flat6pac; 02-10-2013 at 05:54 PM.. |
Thanks Bruce.
