Straight shooter
Good Morning Walt,
Thanks for the response here. I guess the discoloration of the area threw me off given the aesthetic treatment the rest of the case was given. Perhaps there is an explanation for why the same was not done for this machined area such as the machining step coming after the aesthetic treatment. I am aware of the early 7R cases and the attributed strength being partially due to the proximity of the head stud as much further from the smaller diameter 92mm spigot... Looking at the information Bruce provided to us in his manual I also see there were model years without external oil coolers and without case squirters from this range of magnesium cases that are relatively trouble free as you mention. The case squirters were not introduced into production until 1971. The first mag cases were 1968. The first external oil cooler was in the s in 1969. Seems pretty safe to say if those original cases with steel are fine without savers then the later such as mine would benefit from an iron cylinder retrofit as well especially given the cooling tricks we've since learned. I'm curious if Henry has tried this on the 2.7 and await his response. -Andrew
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 03-30-2013 at 03:20 AM.. |
Try not, Do or Do not
No Andrew, I didn't use 90 mm cast iron cylinders because I learned from earlier experiences with cast iron cylinders (2.2 & 2.4) just like the factory did.
The earlier cast iron cylinders were never used to produce an engine that generated real horse power. More horse power always means more heat. All of the early engines with cast iron cylinders were limited in horse power to less than or around 140. What we discovered (I assume the factory as well) was that most of the cylinder heat is concentrated 20 to 30 mm from the head and with cast iron incapable of dissipating the heat efficiently, cylinder head temps went up. Since the heads are primarily cooled by air, the addition of the external cooler had little effect. JB racing cast cylinders (a nice product BTW) uses aluminum fins to cool the cast liner thus limiting the heat build up. Considering the Porsche is a performance automobile designed for an exhilarating driving experience, we always felt 140 horse power in the flat six was droll and undeserving of a place in the rear of one of these gems. So thank you but you can keep your million mile motor and I'll keep helping people build the heart pounding performance the "real" Porsche enthusiast seeks on a budget they can afford.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Straight shooter
So I take it as a "no" that you have no idea what the true temperatures are. The irony of your conjecture statements earlier in the thread aren't lost on me here. You don't have data and you don't know what you're talking about. You will learn something here if you stay tuned. You haven't done this before and you do not know what will happen; neither do I but the data predicts a certain result.
Tell me the answer to these rhetorical questions. Did the early 2.2l / 2.4l engines have case squirters? What about external oil coolers? What about the fan design? What about turbo valve covers? What about deflector tins? You keep building those 2yr warranty engines on 40yr old cars. I wouldn't consider the warranty of significant value unless I were planning to deliver pizzas or run a 24hr taxi service for those 2yrs. I want confidence beyond 2yrs. I will dyno the cast iron cylinder result here.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
There is no reason to believe that the results from an engine with 90/92 mm cylinders would be significantly difference than an 84 mm cylinder given the same material other than to predict that the negative effects would be more pronounced. The larger bore diameter results in even less area for cooling fins. The answers to the questions you ask are well known to most Porsche engine builders. Did the early 2.2l / 2.4l engines have case squirters? Yes. Porsche built engines with cast iron cylinders incorporating piston sqirters as did I. What about external oil coolers? external cooler were available on early cars plus we added then to rally and race cars. Porsche regularly installed coolers on production cars with engines producing more than 160hp back then. What about the fan design? Fan design has remained basically the same. Pulley diameters have changed but fan speeds are a compromise. Too fast at low engine speeds means cavitation (super sonic tips) at higher engine rpm. These high tip speeds mean poor blade function and excessive noise. If you search this forum you will find a thread where I post all the fan and pulley diameters and their effect on CFM and noise related to ducted fans. What about turbo valve covers? Turbo valve covers offer no significant cooling advantage. The ribs on the cover are for reinforcement not cooling. What about deflector tins? Cooling tin has been discussed since the 906 days. Full sized (not trimmed) actually offer better cooling on the cast iron cylinder. We actually reproduce the 906 cooling tin so that the original full finned 906 style cylinders (which we also reproduce) can be cooled properly. Despite your "you don't know what you're talking about" comment we have probably done as much real world development work on these engine as anyone else on the planet. I would ask you: how many professional or DIY engine builders are calling and emailing you for advise / brain-stroming on unusual and often obscure technical problems? I receive some 200 a day from people who have confidence in my opinion as well as confidence in the engines I build. I don't get these requests because I have all the answers or even the best answers but because I offer honest answers backed by years of dedication to Porsche excellence. As for your obnoxious comment about my warranty: I believe it's the best in the business and shows my confidence in our product. I put my reputation and money behind every product I build. Because we warranty our work, we seek the best solution for every problem. Best being a compromise between performance and cost.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-30-2013 at 09:03 AM.. |
Straight shooter
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 03-30-2013 at 09:26 AM.. |
andrerw...cut the s^it here & interact w/ henry & others to discuss your questions...
You are soon to have many folks skip this thread & let you figure this out on your own... Sure appears that you have a drum to beat and are not wanting to discuss your q here... It is ok to disagree with a point(s) someone makes...just move on from that point and continue to discuss the subject w/o creating friction to hopefully fully discuss your q...... So many threads on pelican start out well & go to s^it w/o the topic coming to a full discussion of it...
I live for 911 tweaks... |
Straight shooter
I'm sorry for feeding the troll.
-Andrew
Andrew
The essence of making a forum useful is great restraint when it comes to opinions, and even greater restraint when it comes to getting personal. All of us vary somewhat in our ability to adhere to these goals, but it is worth keeping them in mind. If Henry says he does such and such because he's done it successfully on many motors, I believe him. That may not satisfy my desire for quantification or some other tie to a form of engineering logic, but at least I know that X is most likely going to work. The fact that Henry (or anyone else) doesn't like Y is more of a datum point where there are countervailing views. For instance, Steve Weiner likes the 993 RS or whatnot full threaded Dilivar head studs. Steve has built some pretty potent and strong race motors for customers. Henry believes they are not good to use. Two different forum personalities, two different opinions from guys who get paid to build good motors for other people. Guys building race motors (or wanting to pull well more than stock power out of a street motor) use Nikasil cylinders, or they use something like the JR iron sleeved cylinders - which are pretty much like what Porsche did with the Birals. Few are likely to be interested in seeing how well or poorly all iron cylinders will work outside of the realm of the T motors, perhaps because they simply cannot work as well as the other options in dealing with the heat. Yes, they might deal with differential thermal expansion coefficients between jug and stud, but there are plenty of ways to deal effectively with stud/case issues. Now you are interested, which is fine as an abstract matter, but in this case Henry actually did quantify his views - he had measured temperatures on the smaller bore iron cylinders, and didn't like what he found if the intention was to raise the HP and so create more heat. And his logic in extrapolating this to larger bores seems pretty convincing. And head cooling is pretty important. Porsche found that it couldn't keep the head temps viable with 4 valves per cylinder without water cooling. The change from air and 2 valves to water and 4 has led to an increase in attainable race motor power per liter from 110 hp to 170 with the current DFI motors. Now none of this should discourage you from trying iron cylinders, and measuring things, and so on. Maybe conventional wisdom and weight of authority have it wrong, and there will be a boom in finding junkyard T iron cylinders. I once had a 2.5 race motor built (originally) by none other than Grady Clay. It had 88mm iron cylinders with a 66mm crank. Pretty peppy motor, and the rather small valved/ported heads didn't seem to be in distress. But it got sacrificed for its sand cast case for a 2.7, which was a lot peppier yet. I've still got the Ps, Cs, and heads, which I suppose I ought to try to sell as I'm not going to use them. |
Straight shooter
Straight shooter
Straight shooter
It's not that conventional wisdom is wrong. I'm not here to cure cancer or to win the 24hrs of Lemans. I've been around long enough to hear people who've been working in high performance shops for the same amount of time as Henry tell everyone they meet that you can't safely run a long-duration, high lift cam with a turbo charger. It'll blow up they said. It'll flame out from blow-through they said. You'll have high EGT they said. Someone finally had the balls to put one in and it made 150hp more at the same exact boost pressure. It only took 15 years to shatter that myth in the VR6 Turbo community. Retailers were suddenly scrambling to rebrand their high-lift, high-duration all motor cams as turbo cams... Techtonics 288 cams sold out and were commanding a premium of MSRP. That cam set then went 208mph in a street car at the Texas mile. Go figure. Quote:
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 03-30-2013 at 03:09 PM.. |
up-fixing der car(ma)
Andrew
I personally am interested in seeing your data. A few things - where to begin? on a personal level - I am also a huge VR6 & vintage Porsche fan and interested in a lot of the same engineering stuff you are. I also think that you could be just as much a "straight shooter" and factual/scientific in your analyses as you currently are, while having a more measured tone. I also think you would have a greater positive impact on everyone, and everyone would learn more. You made me debate whether to even address you...but I am too enthusiastic about the technical stuff that I decided to anwyay. I felt it should be mentioned.. ![]() to the meat: you say about engines lasting a long time "when there aren't ridiculous forces yanking the engines apart". That is what is happening. Primarily as a result of revs. I think it's going to be hard to design a sports car engine that lasts a million miles, because although it could be done, it would be an extremely heavy design, and/or, it wouldn't rev very high. These are obviously undesirable sports car attributes. -regarding studs pulling out of mag cases: I'd love to test this in a lab setting: hypothesis being that steel studs pull out of Mg due to excessive expansion of the aluminum cylinder. I would hypothesize that to an equal or even greater degree, the stud pulls out of the Mg due to the loss of strength of Mg at the temperatures in question (not just the expansion characteristics of the Alu cyl vs. the steel stud). In my mind it seems it would be a compound problem, and in general adequate cooling (of the cylinder and the case) seems to address the issues. Anecdotally, other things (valve guides, rings, etc.) seem to fail before the studs rip out on a properly cooled 2.7 type motor (Mag/Nikasil/Steel studs). You are demanding data and a scientific approach but you say things like, "It would be very unwise to run a non-dilavar fastener especially ARP with an aluminum jug on a magnesium case. Failure is practically guaranteed. " Where is this data? Another thought: this is a hobby, for fun, ... there may not be data for every conceivable thing. Maybe there was data but it's in some file drawer or shredder in Zuffenhausen. Maybe it's hard to obtain data. That doesn't mean anecdotal/experiential/qualitative information is irrelevant. People have been messing about with these things for 50 + years or even 100+ years if you consider air-cooled internal combustion engines in general... -Logic and extrapolation are perfectly valid for a given domain. Ie. if you are making 20hp per cylinder and the cylinder is getting too hot, if you make 30hp in the same volume, it is definitely going to be too hot. The domain is the same, so logic and extrapolation seems perfectly valid. Or did I miss some finer point of philosophy, a hypothetical alternative universe where H2O is called XYZ , and Logic doesn't apply..? -everything will fatigue "eventually". Just as "we are all dead in the long-term". The trick is in making this work long enough that it accomplishes what we want it to (whatever it is that is going to fatigue). -I would like to hear more about the rural machinist that builds hundreds of circle track motors. -Aluminum, whether cast or forged and with regards to alloy selection, can have quite different thermal properties. I would venture to guess that the QSC are at the ****ty end of the stick. But I am still interested to learn what you find. -"The difference is the aluminum cylinders warp before iron or steel would. They had to add a liner to increase strength." What do you mean here? Aluminum cylinders can be just as strong as iron ones, they just have to be thicker. Depending on the required strength, the additional thickness could prevent the aluminum cylinder from being viable. But due to light weight and excellent thermal conductivity, imho it is preferred. By liner do you mean the iron of the biral , or Nikasil? Both were done not to make the cylinder stronger , but to surface finish the bore so that an aluminum piston could ride inside the cylinder without galling/destroying it. -Original Biral cylinders were iron cylinders with Al fins cast onto them. The JB Racing "Biral" cylinders have an iron sleeve pressed into an aluminum fin part. The result is vastly superior to the originals - which IMHO are worse from a reliability perspective than solid iron cylinders - assuming temps are under control. The aluminum fins have a tendency to delaminate or "expand off" the iron cylinder center under hot conditions. -finally. Heat is energy. We want heat (to do mechanical work)! You know the racing GT3 motors are running searingly hot inside, on the verge of detonation? Porsche tuned their fuel injection and ignition maps by running these motors ultra-lean with tons of advance to generate failure, just so they could back up a couple notches so it would stay alive right on the ragged edge. That ragged edge is MUCH further with a water-cooled engine vs. an air-cooled one due to the thermal dispersion capabilities of the medium, but the idea is the same. We want the combustion to be as hot as possible, while we want the outside of the cylinder cool! A "perfect" engine would run huge combustion temperatures- enough to perfectly vaporize incoming fuel - and yet wouldn't even require a radiator...
Scott Kinder kindersport @ gmail.com Last edited by YTNUKLR; 03-30-2013 at 11:59 PM.. |
I have been trying to suggest for what seems to be years that the reasons studs pull out of Mag Cases is qualitatively quite staightforward.
There is clealry a realtionship between time, temperature and force. and is any one of the treee can be reduced then the result will probably mean that the engine survives. The Tensile Strength of most Mag Alloys does reduce with temperature. The loss of strength would be linear with temperature to about 200degC when it would start to drop steelpy. At 150degC the loss of strength would be typically around 15%. Some of the more recently developed alloys used for Military Helicopter Gearbox casings are much better but they wereen't around in the Sixtires/Seventies. The more significant impact on pull out behaviour would be due to stress relaxation - which is a form of creep behaviour. When a material is subjected to a continuous force and even moderate temperatures crystal defects can mecome mobile and due to diffusion effets a loss of strength occurs. The influence of time/temperature/force can be plotted as a 3 Dimensional surface and changes in any one parameter can have a big impact on success or failure of a set of components. Over long periods of time strengths of materials can be very seriously affected but the 'damage' to the structure would be restricted to those areas being subjected to the highest level of stress. Clearly managing temperature is significant as there will be a critical temperature below which the thermally activated mechanisms that cause this damage will not operate. Reducing stress also gives a beneficial result and should allow the engine to survive. The arguments centre around the best way to achieve the result. It is quite clear that engines with well managed temperatures and case savers seem to survive even with Aluminium Cylinders, Early Magnesium engines with Biral or Cast Iron Cylinders also seem to survive even without case savers and with steel studs The biggest problems seem to occur with Mag Engines, Thermal Reactors, Aluminium Cylinders and Steel Studs. These engine are the hottest running, have high stresses due to expansion and stud tyoes. The argument then seems to take on a almost religious aspect. If we consider the solutions one by one then we should be able to draw some simple conclusions. 1. Case Savers These parts certainly will reduce the local stresses in the engine case and this will reduce any stress relaxation effects and assist with the case retaining its basic properties. This seems to me to be a major influence. 2. Cylinders The lower the expansion of the cylinder the lower the stresses on the the threads the less likely the incidence of failure. I am sure there are many arguments about cylinders but they cloud the issue of thread failure. 3. Studs As I have tried to say before the only influence that the stud has to pulling out threads is its coefficient of expansion. A Dilavar Stud must reduce the stress developed in the threads even when used with a case saver and regardless of the type of cylinder. If the primary concern is to preserve a Mag Case then a Cast Iron Cylinder, A Case Saver and a Dilavar Stud along with as much cooling as you can bolt on must be the safest bet. If there are other more important objectives that mean cylinders need to change, for example, then there may be other solutions that are better. The real trick is, as has been said, to try to use logic and a basic understanding on the engineering and to try to eliminate the contradictions. It is interesting that we often use 'Porsche's Design Office' to justify some arguments but contradict some of their decisions when they don't suit our case. Dilavar and its like/dislike is, of course, the classic example. ![]() |
Straight shooter
Straight shooter
As for warping...the topic would be deformation. Not sure how far you want to dig in here. Commonly understood that aluminum deforms under far less pressure than cast iron when everything else remains equal. Chris covered this earlier in the thread. Fact not opinion. Basic example: Go out to your average chevy and whack the side of the aluminum head with a hammer and look at the dent. Now whack the cast iron block and notice nothing. Add heat and it only gets worse for aluminum... Quote:
https://www.forging.org/system/files/field_document/FIERF-AISIFinalExecutiveSummarySept04.pdf Quote:
The fact that race teams (not just Porsche) tune to the balance between lean and power and material capabilities is because of competition and sanctioning rules. They too are often trading off all-out performance for fuel economy on certain tracks. Sorry about that last tangent - seems we're down a bit of a rabbit hole getting into tuning theory even though it does relate to the temperature discussion. The test will be with PMO carbs so tuning options will be somewhat limited.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 03-31-2013 at 08:47 AM.. |
Straight shooter
Are there any examples of direct port water methanol injection used on normally aspirated 911 for detonation suppression? Huge cooling benefits on the non-Porsche turbo cars I've used it on. Have a system here on the shelf that may also find its way in.
Good introduction for those unfamiliar; this is on a difference engine design but covers the basics: http://www.youtube.com/watch?v=skuIkE93TR8
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 04-01-2013 at 06:53 AM.. |
Straight shooter
Thanks for the reply,
And you're worried about my dignity? I'm not, particularly, so I'll call a spade a spade and tell you you're an ass.
'90C4 |
Straight shooter
If you have something tough to say to me then PM me. Putting in a show for your pals isn't going to end well for you.
Edit: And by not ending well I mean with respect to forum rules/moderation and nothing more. Just so we're clear for those with wild imaginations.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 04-02-2013 at 12:57 PM.. |
The Carrera RS 2.7 engine differed from the then current 911S 2.4 litre only by its cylinders of 90mm bore. But to achieve that bore size, the cylinders had to be changed from Biral to Nikasil (alloy cylinder and fins with an electrolytically deposited layer of nickel and silicon carbide forming the working surface) because only the thinner walls of the Nikasil cylinders made it possible to get a 90mm bore within the maximum possible lower flange diameter [spigot]. Quote:
If Weissach determined that it's not possible to build 90mm cast iron cylinders to fit within the existing head stud spacing, why are the aftermarket people making them, that is the question? |
