WTB: piston Cylinder..adj pict..
![]() thanks JP |
What you need to complete the request is bore size, stamped on the outside of the cylinder on the top. 0, 1, or 2 next to the deck height which is a triangle with a 5 or 6 inside it.
If you want the piston to match yours you need to post the 95xxx number cast inside the piston. Youre looking a KS alucil so you should look a piston and cylinder unit that has already run together. Bruce |
I can provide a P&C pair
Tom is a good guy.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
