Good luck with your Second rebuild project.
I will be watching to see how it goes.
I learned a lot from the excellent posts on your last projects.
Peter in Melboune
Old 03-24-2013, 10:19 PM
KTL KTL is offline
Schleprock
KTL's Avatar
You'll want to check your rod(s) for proper big end sizing since the knock is the rod beating on the rod journal due to excessive clearance. BTDT last year when my motor let go and luckily the rod stayed on the crank (yay for Pauter rods!) and didn't see sunlight until I took the engine apart.
I have an extra set of good stock 3.0L rods for cheap. Let me know if you need a set or want to see if you can match up one if the weights work out.
Kevin L
'86 Carrera "Larry"
Old 03-28-2013, 02:21 PM
Free minder
Aurel's Avatar
Progress
I have removed the right cam tower. I see no scuffing on the cam lobes, which is good sign. The cylinders walls are nice too. It looks like no debris made their way into the heads. But the noise was on the other side, and I have not gotten there yet because the woodruff key in the cam is stuck. I am going to get a pair of side cutters to convince that key to let go...Then I will report my findings on the left side.
https://picasaweb.google.com/ad8588975/Rebuild2#5861581223190423730
https://picasaweb.google.com/ad8588975/Rebuild2#5861581235484162466
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 03-31-2013, 12:02 PM
Free minder
Aurel's Avatar
This does not look good
I have removed the cylinders now.
There is sign that one piston kissed the valve. I am assuming that is because the rod bearing under that piston was trashed.
https://picasaweb.google.com/ad8588975/Rebuild2#5861673182198894162
I also have scuff marks on 3 of the pistons, and the cylinder bases have groves that do not pass the fingernail test...
https://picasaweb.google.com/ad8588975/Rebuild2#5861673198823092850
Old 03-31-2013, 06:06 PM
Straight shooter
Lapkritis's Avatar
Tough luck on valve contact. Have you worked the economics of the machine work coming your way against a replacement engine? Tough spot to be in...
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-31-2013, 07:43 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Sorry to see that piston & cylinder damage. That stinks.
Could have been worse. I know that's not much consolation. Just saying that it could have been much worse. I've recently BTDT (and still "doing that")
Engine Bearing Failure- Disassemble Heads Too?
The economics of a replacement engine are not in our favor. Sure you can get a used engine for around $3K to $4K. But it's of unknown condition and one's often inclined to open it up for some work before putting the engine into service. The costs start adding up fast.
Whereas collecting used replacement parts is usually much cheaper when you're DIYing it.
Kevin L
'86 Carrera "Larry"
Old 04-01-2013, 07:12 AM
Free minder
Aurel's Avatar
The good news is, if I have to replace P&Cs, I may bump my compression and displacemement a bit .
I have to see if the head where valve-piston contact occured is damaged. I would expect at least the valve will need replacement. What else?
What really will decide how I procceed is how the crank looks like...
Old 04-01-2013, 11:26 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Valve contact can mess up the seat if the head is cocked. Also should replace the guide since the piston would knock the valve up against it.
Any time you install a new valve(s) you should have the seats cut anyway.
Kevin L
'86 Carrera "Larry"
Old 04-01-2013, 02:38 PM
Free minder
Aurel's Avatar
Little progress
I removed rod#6 and was able to confirm my initial diagnosis of spun rod bearing. I measured it and it does not seem to have stretched more than 100 mircons, but I will have to measure all of them to compare. I can see the crank surface is damaged, will have to be polished at least...I havent split the case yet but I am getting there.
Old 04-12-2013, 03:32 PM
AlfonsoR's Avatar
Maybe I'm not looking in the right place, but the piston scuffing could be normal piston slap?
"Simplicity is supreme excellence" - James Watt
Old 04-12-2013, 09:28 PM
Green993's Avatar
Just curious - What are your plans regarding the oil tank? Just clean it? KTL, what did you do in your rebuild (oil tank)?
Good luck on rebuild, will follow.
Old 04-13-2013, 02:26 PM
KTL KTL is offline
Schleprock
KTL's Avatar
I'm not going to say piston scuffing is common. But you see it a lot. Light marks on the skirt and cylinder are OK. But once you start feeling ridges on those marks, it's a problem.
Oil tank can be cleaned. It needs to be ultrasonically cleaned to get any bearing material out of the tank and its upper screen. After the oil comes in the bottom of the tank, it goes up a tube that puts it thru the filter. When it comes out of the filter, it gets dumped on the screen to de-aerate it. Point being is that the screen should be free of debris since the filter should catch everything. But when there's a bearing failure, you don't want to take any risks.
My tank is full of bearing debris because in my infinite wisdom, I used full flow (non-bypass) Canton filters. So when my engine unleashed a shiatstorm of bearing material, it clogged the filter and then collapsed the filter cartridge, allowing bearing debris into the tank too.
Kevin L
'86 Carrera "Larry"
Old 04-15-2013, 08:50 AM
Free minder
Aurel's Avatar
One of my cylinders has a ridge that I can feel all the way up, and I am concerned this may cause oil smoke, low compression, etc...Luckily, I may have found a set of Mahle P&Cs, and even the rods, for a very low price. So low that I could not pass it. I took a little gamble there, but we'll seewhat I get. Looked very nice on the pictures.
Old 04-15-2013, 10:27 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Sometimes those gambles work. I did same on a set of '85 pistons and cyls and got a nice low mileage set that had been sitting for decades after the car got wrecked. Also sourced a set of like new axles from same guy. $50 for a set of 16K mi. axles that just needed cleaning.
Let me know if the rods don't pan out for you. I have an extra set of SC rods that I got with a replacement crank. My episode was a bit worse than yours, not to mention my crank was near min. STD spec before the failure. So I decided it'd be cheaper to get a good used crank vs. having mine welded & reground back to STD
Kevin L
'86 Carrera "Larry"
Old 04-15-2013, 11:58 AM
Free minder
Aurel's Avatar
Here what my engine configuration will be once I am done. Pretty much what Wayne calls an upgraded 3.0L CIS in his book:
Large intake ports (already have)
DC 15 cams (between SC and 964, already have)
9.3:1 CIS pistons and Mahle Cs from an 82 (should be here tomorrow!)
74 backdated exhaust
Lightweight pressure plate (since I have to do a clutch job, why not?)
This should give a fun reliable street motor if I do it right...
Old 04-16-2013, 07:03 PM
UnRegistered User
billybek's Avatar
Hope those pistons and cylinders work out well for you. I saw that you snapped those up not long after they were listed on the for sale forum.
Are those cylinders Nikasil?
Bill K.
Old 04-16-2013, 08:12 PM
Free minder
Aurel's Avatar
According to the stamp on them, 95zn1 w16 is for Mahle Nikasil. I also counted the fins, they have 11, my KS Alusils have 10. But I could be wrong...worst case scenario I got another set of Alusils with higher compression pistons. And a set of rods.
Old 04-16-2013, 08:59 PM
Free minder
Aurel's Avatar
I received my P&CS set, and they are indeed Mahle Nikasil, in very nice shape, coming from an 84,000 miles 82'SC. I measured the cylinder bores, here are the results:
1 94.98, 94.99
2 94.98, 95.00
3 94.99, 95.01
4 95.00, 95.00
5 95.00, 95.00
6 95.00, 95.00
I also measured the compression ring clearance on the pistons, and it is very tight, while on my old Alusil pistons, the clearance is over 100 microns.
Unfortunately, the set was poorly packaged, and one of the piston skirt got broken during shipping.
https://picasaweb.google.com/ad8588975/Rebuild2#5868442018078026082
So now, I must find a replacement CIS piston Mahle 95L67 9.3:1 CR. If anybody has one please let me know...
Also, the pistons and cylinders were separated, how do I figure out how which piston goes in which cylinder?
Old 04-20-2013, 12:25 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Sorry to see one of your piston skirts was damaged. That's a real kick in the junk.....
I'd not worry about the pistons being separated from the cyls, should you plan to re-ring them. Seems worthwhile to get new rings as they're not terribly expensive & you don't know which piston goes in which cyl.
Going forward, i'd take your piston measurements (skirts) & compare with cylinder diameters. Mix/match pistons & cyls to best balance the clearances per the specs.
Kevin L
'86 Carrera "Larry"
Old 04-22-2013, 06:58 AM
Free minder
Aurel's Avatar
Will definitely rering the pistons. I have several leads for a piston replacement, but the challenge is to find matching weights. If no luck, I may just buy a new set of JE pistons. But for now, the focus is on the bottom end. I had no issues removing the flywheel bolts, and have removed all the bolts, even the hidden ones, for splitting the case. Then, after reading all the threads I could, I started tapping the 4 corners to separate the cases. Second evening I try with no luck. How long is the tapping supposed to take? What are the best tools? I even read about Henry Schmidt method of hitting the yoke but I could not figure out how that would work. I just don't like beating too hard on that case...
I even found a cool video showing case splitting, seemed easy...
http://m.youtube.com/watch?v=8DtBJKUctMU&feature=relmfu
Old 04-24-2013, 08:31 PM
