worn cam lobes
I am working on this engine from a 914-6. The cam shafts are both worn at the lobes for cal 3 and 6 to the point where you can feel a ridge where the material has been worn away by the rocker arm contact points. Given the replacement new cams are expensive, can I just take these to a grinder and say clean this up ? Is there any hardening of surface required after cleaning?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-20-2013, 06:01 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If the lobes are worn down...you may have to have them built up with weld before regrinding...to keep the profile and height correct.
Bob
Bob Hutson
Old 03-20-2013, 11:40 PM
Straight shooter
Lapkritis's Avatar
Re: worn cam lobes
Check the oil feed tube for blockage in the tower especially near the worn lobes. Compressed air/fluid to the feed fitting should make blockage evident.
-Andrew
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-21-2013, 08:48 AM
Green993's Avatar
Elgin Cams in Santa Rosa did a very nice job and very fast turnaround on my 993 cams. They did a regrind and hardening for about $400 + Shipping.
Old 03-21-2013, 09:10 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Agree Elgin is a good source for a regrind.
Good advice regarding the spray bars. The holes in the cam spray tube are so small that I don't like risking blockage by just shooting some solvent or air thru them. Best to pull the plugs by drilling & tapping them for an M6 screw and then draw them out with a "puller" arrangement. I use a deep 10mm socket and some washers to use the M6 screw as a puller.
Once you get the tube out you can get a good look in there and clean out any crud. I always seem to find something lurking in there.
Kevin L
'86 Carrera "Larry"
Old 03-21-2013, 02:44 PM
safe's Avatar
What kind of engine, wasn't most 914-6 T engined?
If so a used good cam is dirt cheap.
Magnus
Old 03-21-2013, 03:13 PM
I am leaning to a used good cams route. Regriding at $400 vs $100 for used cams...
Old 03-21-2013, 07:19 PM
KTL KTL is offline
Schleprock
KTL's Avatar
True there's a good savings in used vs. regrind. Just be wary. Some people's idea of good used may be no better than what you've already got. Been burned quite a few times by people's ignorance about what is truly good condition. Just my opinion.
Kevin L
'86 Carrera "Larry"
Old 03-22-2013, 06:37 AM
Straight shooter
Lapkritis's Avatar
Re: worn cam lobes
And be aware of the impact on the rocker pads if the profile doesn't match perfectly to the previous cam profile.
Old 03-22-2013, 07:40 AM
