bracket identification
bought a disassembled 3.2L motor, nearing the end of rebuild and i have unknown bracket. Part was in bags with the cam tower oil lines. I have had no luck finding on parts lists, need some help identifying the small bracket.
Old 04-11-2013, 04:53 AM
sorry, forgot picture.
Old 04-11-2013, 04:59 AM
left side chain box top with the 8mm nut supports the spark plug wires.
Bruce
Old 04-11-2013, 05:20 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Bruce
Yep. Bruce is the man as usual.
Kevin L
'86 Carrera "Larry"
Old 04-11-2013, 07:14 AM
Thanks Bruce. won't use this one going twin plug. Can you use the part? can have it for nothing, be good to be put to use, I did re-plate the part, was after my plating learning curve, so the plating turned out really nice.
Old 04-11-2013, 07:32 AM
Thank you, but no thanks as I would have to detail everything to that level....I just like clean.
Bruce
Old 04-11-2013, 08:13 AM
