bracket identification
bought a disassembled 3.2L motor, nearing the end of rebuild and i have unknown bracket. Part was in bags with the cam tower oil lines. I have had no luck finding on parts lists, need some help identifying the small bracket.
sorry, forgot picture.
left side chain box top with the 8mm nut supports the spark plug wires.
Bruce |
Schleprock
Yep. Bruce is the man as usual.
Kevin L '86 Carrera "Larry" |
Thanks Bruce. won't use this one going twin plug. Can you use the part? can have it for nothing, be good to be put to use, I did re-plate the part, was after my plating learning curve, so the plating turned out really nice.
Thank you, but no thanks as I would have to detail everything to that level....I just like clean.
Bruce |
