What Happens If...
well not really a if questions but what is the outcome if i put 3.0l turbo pistons on a 3.0l SC engine?
do i need to change anything besides adding a turbo (already have that in mind) anything else like connecting rods, cyl, ETC..
and what happens to the C/R if possible???
Old 04-24-2013, 12:57 PM
AlfonsoR's Avatar
From another recent post, the exhaust valves of the turbo are made of an upgraded material, nemonic. Not sure about the pistons or anything else. What you can do is compare part numbers for the various internal parts.
"Simplicity is supreme excellence" - James Watt
Old 04-24-2013, 04:41 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I would think that any turbo pistons would be of lower compression than regular ones.
It makes sense...the turbo adds pressure...so the pistons have to be lower ratio to prevent detonation.
Bob
Bob Hutson
Old 04-24-2013, 11:10 PM
Ingenieur
Probably need to make sure you have nikasil cylinders. Forged, non-plated turbo pistons are for nikasil only.
Old 04-25-2013, 06:24 AM
bump
Old 05-05-2013, 08:18 PM
haycait911's Avatar
I looked at doing this a while back. the compression ratio was just too low. tried a lot of approaches to get the cr up, and a few would work, but it reaches the point of diminishing return. more trouble than it's worth.
these ones......
Mahle 3.4L P&C (mint cond) 98mm Turbo
Old 05-05-2013, 09:04 PM
what about a twin turbo approach is that out of reach with the P&C too??
Old 05-05-2013, 09:30 PM
haycait911's Avatar
oops. I mis-read. if you're putting on a turbo, then the p/c's make sense. I know nothing about turbo engines so I'll fade away and let others chime in.
Old 05-05-2013, 10:42 PM
bump
Old 05-28-2013, 01:41 PM
Try not, Do or Do not
Henry Schmidt's Avatar
There is no issue with adding twin turbos as far as the pistons are concerned.
The big issue is that the factory 3.0 turbo pistons only make 6.0:1 compression making it almost impossible to build an engine sans huge turbo lag.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-28-2013, 01:57 PM
well then what about stock cyl. and custom pistons giving C/R to 7.5.1 or 8.0.1?
Old 11-14-2013, 04:33 PM
