I think I have got cam timing on the older, big nut, cams down. But with the bolt end cams I no longer was able to rotate the cam but not the gear (pin out), which is what makes doing the older cams pretty easy once you get the hang of it.
With the bolt style, eventually I could get the pin in so the cam was close to where I wanted it. Then I stuck a punch end through a suitable hole in the gear and used that against an inner tooth to nudge the cam so the dial indicator got closer to where I wanted it, and I could tighten the bolt some, enough to keep the dial indicator there, and then remove the punch, insert the gear holder tool, tighten more, and finally rotate the engine to see if it was close enough to go to final torque and move on. But those who have worked much longer and more with this style cam end must have come up with something better? There is so much slop that I don't see how one can use just the pin to get where you want to be unless you are very lucky. Or so patient you can do something I'm not sure I understand, which is to skip teeth and take advantage of the fact that (I guess) the holes on the gear aren't symetrical with the teeth. |
I have the later style cams. I put assembly lube & motor oil on the gear where it sits on the cam. Chain tension is just provided by the stock tensioner - adding force just makes everything harder to do, it does not seem to alter the results.
To make the adjustment, I plug the pin with sparkplug into one of the holes, no cam bolt at all; I don't bother unscrewing the sparkplug either, it just sticks out of the cam gear. Once the dial indicator reads what I'd like, I pull the pin & rotate the crank. If the cam rotates along, it tends to do so in one direction but not the other - so I overcorrect and then approach the timing from the other side, where the cam seems to stay put. Once it's all set, I torque the bolt & re-check - it rarely moves more than 0.002 or 0.003 ". YMMV
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Smoove1010
I stopped the cam-rotation issue by sticking an awl into one of the other holes in the gear, then using that to ever-so-slightly "wedge" the gear-to-gear alignment to get the indexing pin into the next hole over, followed by a re-test.
I think the issue is caused by rocker pressure on the cam lobe, causing it to rotate - particularly when only one rocker is installed, and there are no other rockers holding the cam in place, or perhaps even pushing another lobe in the opposite direction. When I practiced this process during disassembly (described here: 87 Drop Top - Drop-n-Top End) I did so with all the rockers still installed, and there was no rotation of the cam when I jogged the crank backwards a few degrees. That was easy. This time was a little harder. GK |
GK - I am with you. That's what I think also.
With the old style/big nut cams, you had plenty of leverage on the cam to resist the spring pressure of the #1 or #4 intake. Once set, you didn't care. And installing just one rocker (or an exhaust also, so you can check valve clearances) makes sense if you might need to pull the heads off again. But with the bolt style cam, I'm thinking a guy ought to figure out which other cam/rocker/valve would be pushing the opposite way. The valve you use for setting timing is going to be pushing open, so it will want to move clockwise. Ought to be one of the other five which will be pushing counterclockwise. Less hassle than installing them all. The one time I rechecked timing with them all installed, I was pleasantly surprised to find the cam didn't want to turn all on its own due to spring pressure. |
Smoove1010
As a newbie to this process, the many posts on the subject were very helpful, but this video really de-mystified it for me:
N Fulljames cam timing.wmv - YouTube It was kinda fun but I'm glad I'm done. It's really good to see the covers going on, the whole engine being closed up, and I'll be putting tins on shortly. |
Schleprock
Kevin L '86 Carrera "Larry" Last edited by KTL; 05-07-2013 at 08:30 AM.. |
Schleprock
I found the bolt-end cams to be pesky when the sprocket would not slip on the cam snout with the pin removed. I used to attempt setting the cam to a position that anticipates that inability to rotate it with the pin out and nothing to grab onto. It was a frustrating vicious cycle of back and forth fiddling that didn't allow me to precisely set the cam where I wanted it.
I think it was flat6pac (Bruce) or Mike Bruns who suggested to insert the bolt with the big washer removed and snug it in place by counterholding the sprocket with the special tool and then bottoming the bolt head on the end of the cam. No need to gorilla tighten it. Just mildly tight enough to allow you to rotate the cam via the bolt head w/out the bolt loosening. Kind of like double-nutting. Then you can use the bolt head to rotate the cam forward or back to set your desired lift spec.
Kevin L '86 Carrera "Larry" |
Kevin
I tried that, but must have done something wrong. I can see how it would work for getting the pin in a likely hole. But not for dealingwith the wiggle room at a given pin setting. Because at that point you need the big washer on and to snug it down to hold the reading. And loosening the bolt moves the cam, and the holder doesn't help because it grabs the gear, and not the cam. So spring pressure can let the cam move until only the pin holds it. So if that is not optimum, you haven't gotten anywhere. Porsche seemed to think that using the pin to do all the locating before torquing was satisfactory. But they weren't thinking of guys like us who want the two sides to be almost exactly equal, or who are fixated on being within a couple of thousandths of an inch. Nex time I do this (which, alas, is sooner than I wanted), I'll have to look into the "add a second rocker" notion to deal with spring pressure. |
Schleprock
Very true about dialing in the setting when you've already got your pin selected, and you're just "getting it to within a gnat's ass" within the pin hole slop.
Solve all your precision problems and get a set of Mike Bruns' JB Racing adjustable cam sprockets. They look like the bee's knees (never understood that expression....) JB Racing - Porsche Engine Components Just gotta decide if $400 is worth it to you to get it dead nuts perfect the way you want it.
You are right - I have hankered after those. I've got a VW Beetle with a somewhat similar setup (much less expensive). That would cut through all of this.
Porsche, on the other hand, now requires you to use a sort of jig on the newer water cooled 6s (maybe started with 993s?) which plugs into back end of the cam. That sets the cam, set the crank to TDC, tighten, move on. Maybe they needed something like that with vario-cam and all that? |
The tools were fine. I took time to develop a method and a spreadsheet for taking the measurements and checking my math. I tend to dwell on a task until I understand what I'm doing which can take a while and I wasn't in a rush, was taking my time and enjoying the method I came up with. If you can take the measurements just a few times and be confident in your math, then it doesn't need to take much time.
Sold: 1989 3.2 coupe, 112k miles |
Walt, if you install a second rocker be sure it is fairly loose so you don't run the valve into the piston while spinning things around! With just the intake, you tend to stay clear of the piston. If you also have a correctly adjusted #1 / #4 exhaust rocker, for instance, it will make contact while doing the adjustment ... you can guess how I know?
![]() The pins on my car seem to be accurate within +/- 0.002, which I'm pretty sure is indiscernible from an engine point of view. Based on how the rocker arm geometry (how was the face ground / worn, what angle is the rocker at based on valve seat & face grind) and changes in valve timing caused by expansion of the engine case when it's hot I bet you're getting that level of variation and then some anyway. If you decide to be picky nonetheless, you could probably rig up some sort of thing from a big (1/2" or 3/4" x 1" long) rare earth magnet and a thin steel plate with a "V" ground in it glued to the magnet, inserted through one of the other rocker arm cavities onto the camshaft. They are surprisingly strong, and would probably hold the cam enough to move it - just be sure you have it attached REALLY well to whatever handle so you can remove it later, if the handle were to come off you would have serious issues getting the magnet off again! I'd drill a 1/4" recess in bar stock & use superglue. We have a few on our fridge, and they're almost impossible to pull off without sliding them off the side. I bought them for my kids to play with, but decided immediately upon trying to separate 2 of them that they are not suitable for kids...
I don't quite follow the interference issue. You are saying that starting with an approximation of the intake overlap (dot on cams up), you might be far enough out on an exhaust that you'd get interference? I'll bear that in mind when I try this balancing act. With the big nut cams, I can get the intake spot on from the get-go (+/- pin slop). But has been harder with the bolt end style. I should be able to at least get a pin in so the overlap is within the range of my pin slop, which should mean that when I find a counterbalancing valve (another intake? or an exhaust, but one which is pretty much as close to closing as the intake is open - hmmm, sounds like the exhaust on the same cylinder at overlap) spring I should be close enough not to have this happen.
I wish my experience showed only 0.002" valve height difference due to pin slop. I am remembering more like 0.025", and I never have gotten as close as 0.002 with just the pin. If I could I'd be a happy camper. Not sure how we have such varying results. Maybe I'll take some spare parts and just measure slop. I probably can do it directly with a fixed inner, a pin, and a dial indicator on a tooth of the outer. Should be able to translate that into degrees, though that won't be exact as to overlap, as that depends on some other things, the cam profile most acutely? |
On my engine (motronic has a high dome piston) there is a very narrow range of cam timing where intake & exhaust clearances are adequate. Other engines are probably different!
It sounds odd that you're getting .025" variation - that seems really really high. Valve lift spec for 3.2 motronic at TDC is only 0.049", +/- 0.007" or something like that! Sure you're not remembering variation in mm? The pin seems a pretty tight fit, I cannot imagine more than a degree of slop in there. If there is a bunch of slop for some reason, you could turn a new pin that fits tighter maybe? It's also possible that your cams measure lift at a point where the change in valve lift per deg crank revolution is much greater than on my 3.2, in which case the tolerances ought to be much larger to make up for it?
I've seen this (pin slop greater than any sensible tolerance) on my 2.7 and SC motors (overlap about 1mm) and race motors (overlaps 5.8 -6.2 range). Dial indicators in Metric are ridiculously more expensive than those in inches, so it was only when electronic ones with a switch for either system became available for reasonable prices that I could use metric. I'd never have worried about 0.002" variation. I've used (for better or worse) 0.005" as my side to side tolerance as long as both readings were within limits for the race motors (clearances so tight that not much room to move timing around), or close to the dart I threw for the SC, given all the settings which work for that cam.
As I recall, the early 911s had an inner which had full holes, while the subsequent motors have half holes (look more like gears, though not). But I've had the slop with both. There is a system which takes advantage of the different ratios between the crank/IS gearing, and the IS/cam gearing. Since the pins are a vernier system, if I remember this right, if the timing you want does not end up with the valve spring pulling the pin tight against the outer's hole at a reading you like, you can loosen things all up, and move the chain wheel one tooth one way or the other. This will give you a slightly offset selection of holes, and you can continue to do this until you find the magic combination. But this is kind of tedious. And ultimately it is not the pin which withstands the torques involved. The pin just holds things in place until the big nut or small bolt are fully tightened, at which point it is the friction caused by fastener stretch which locks things in place. |
