Cold Miss
Fred,
Glad to hear you are making positive progress, not sure how old your injectors are but sounds like a similar problem I had. I did remove the old one’s at one time. Tried my best to clean them, reinstalled, same problem. Finally broke down and bought a new set, major difference.
Dan
1985 Porsche 930, K-27, B&B exhaust, Tial WG, ER suspension, money pit.
"We are a bullet now - except faster"
Old 07-14-2013, 08:17 PM
Smart quod bastardus
fredmeister's Avatar
Originally Posted by Daniel930 View Post
Fred,
Hi Daniel,
The injectors were sent out to be cleaned and flowtested by Turbokraft 2 years ago. They were all noted good and sent back to me. I did make sure to install the best flowing injectors in the #2 and #5 cylinder location since those cylinders recieve the most air flow thru the pancake manifold, in an attempt to balance AF ratio between all the cylinders.
Later,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 07-15-2013, 03:34 PM
Here is a screen dump of my stock ignition curve that I have programmed into the MSD box.
Welcome any feedback from anyone on what they think or improvements I could make.
Old 07-15-2013, 03:49 PM
