1973.5 updated timing chain cover stud woes
1973.5 CIS 911 Targa
Finally installing the updated chain tensioner kit I bought a few years ago in my restoration project. Unfortunately, on the right hand timing chain cover a small stud pulled right out trying to fasten it down. I guess I now know where the previous owner had an oil leak. Anyway, I need the know the right part number for this small stud as well as what size heli-coil kit to get to repair the timing chain housing.
Also, the left hand side cover appears to need two longer studs on top than what my stock timing chain housing has. If anyone know the proper part number for those I would appreciate it. Thanks.
Old 06-20-2013, 07:20 AM
Straight shooter
Lapkritis's Avatar
Here's what I did to adjust my left side cover for the smaller studs.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-20-2013, 08:43 AM
Generally, its any bolt long enough...
Old 06-20-2013, 12:01 PM
The studs are 6mm x 22mm, Porsche part number 999.062.102.02
I think the 2 longer ones are 42mm long.
I used two long bolts and cut them to length to make studs. I filled the gap in the cover with some 5/16" tubing and used a larger flat washer.
Old 06-20-2013, 06:49 PM
E Sully's Avatar
My tensioners were installed by a shop and they used 2-6mm x 40mm bolts.
As for the pulled stud, have you considered just re-tapping it and using an 8mm stud instead of the original 6mm?
Ed
1973.5 T
Old 06-21-2013, 10:23 AM
notmytarga's Avatar
I've been in there on my 75 and some of this isn't making sense. The bigger/longer studs on mine were for the Air Pump which I deleted with a flourish. Initially I buttoned up the covers with spacers. During tensioner install I replaced the studs with M8 shorter ones. If the stud hole is stripped something odd was done - I would tap and place an insert. Lapkritis - what did you do to the cover there - is material added?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 06-21-2013, 10:36 AM
E Sully's Avatar
It seems he drilled it out to recess the fasteners, instead of using longer ones.
Ed
1973.5 T
Old 06-21-2013, 11:14 AM
Straight shooter
Lapkritis's Avatar
Yeah, drilled so the regular studs were left alone on the left side. Measured intended depth and put tape on the drill bit for a visual stop. Works a treat. No fastener games.
Old 06-21-2013, 11:55 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Here's how we do it. Machine the excess material from all 3 bosses so the cover looks closer to the early cover. This one is a factory RS light weight. We were trying to keep it looking as original as possible and still meet the owners desire for Carrera tensioners.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-21-2013, 07:38 PM
