urgent help with cam towers!!
cross post from tech forum: (my first engine build)
I just received some 78-79 cam towers from a pelican gentleman. Fed ex mine (from an 88 3.2) are stamped: 964-105-111-0r the 78-79 ones i received to replace those are stamped: 901-105-111-1r they sure look the same , and both are 4 bearing are they completely interchangeable?? Help!! Trying to finish my long block tonite!! Frank |
Schleprock
Yep Frank. 4 bearing all interchange. Well, except for 993.....
Funny you are doing the reverse of what I did. I had to acquire some cam towers after I destroyed all the bearings in my engine. I got some towers from a '964 turbo with the 964 part number. They bolt up just fine with my '79 heads and '85 cylinders, to replace the '79 towers I roasted (cam bearing bores all scored badly).
Kevin L '86 Carrera "Larry" |
If cam towers are no longer usable on a motor they still make a nice place to mount 3 heads in a row while porting them with a die grinder.
