How important are matching wrist pins to pistons?
Hi guys
How important are matching wrist pins to pistons on a 3.3 the machine shop might have mixed them up.
From your experience all wrist pins measure the same?
Erick
Old 11-26-2014, 06:26 PM
abit off center
cgarr's Avatar
They should all be the same but I like to match them by weight, mix and match pins and pistons to get each set close to the others.
______________________
Craig
G2Performance
Old 11-26-2014, 07:35 PM
Not important at all.
Old 11-27-2014, 09:49 PM
Wrist pins vary by less than 1 gram pin to pin
Pistons vary by several grams piston to piston within a set
Old 11-28-2014, 12:49 PM
Thanks guys
From your experience all pins are the same diameter?
Old 11-28-2014, 01:02 PM
Walt Fricke's Avatar
That's what they are telling you. Same diameter. Which is why you can use their small weight differences (or shave off a bit of weight from one) to help fine tune piston overall balance.
Old 11-28-2014, 11:11 PM
