NEWFIE 69 911E's Avatar
Interesting video - 911 head resurfacing
All,
I am preparing to complete a top-end rebuild due to a broken head stud on my 80 911SC. Will post here when I get started
I anticipate that the heads will need to be resurfaced - found this related video that may be of interest:
Resurfaceing the Porsche 911 Cylinder Head - YouTube
Safe and Happy Motoring,
Tom
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 08-21-2013, 06:27 PM
+ another interesting site: Milling machine | GordsGarage Blog
1969 911E Coupe
Old 08-21-2013, 06:39 PM
It's funny you have both of those videos posted.
After I saw "fiatnutz" youtube clip, I asked Gord of "GordsGarage" if this was something he could do.
As you can see from his blog, he accepted my challenge.
I am very happy with the machining he did. In addition to resurfacing the heads, he also cut down and pressed in my new valve guides. I did the easy part of removing the old valve guides and left the hard work for Gord. Once he installed the new guides, I used a hand cutter and quickly re-cut the valve seats.
I'm hoping to get my butt over to his place sometime in the next month to bead blast and powder coat all my engine tin.
Once I get the engine back together, I plan to pull the motor from my other '73 and get him to do the same head work, hope he's still up for it.
Old 08-21-2013, 10:55 PM
jrbennett, if you don't mind me asking, how did you size your guides to the valves? Did you hone them or ream them? I'm wondering if this is a diy job or if you had to have it done.
thanks for any info.
Old 08-22-2013, 11:27 AM
I really like the videos - they provide some nice clear images of what the head surfaces look like before and after resurfacing
1969 911E Coupe
Old 08-22-2013, 02:40 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Note that in John Edward's video he used a piece of an old cam housing as a way to make an adapter/fixture to hold the head in the lathe chuck. I've got quite a few junk housings if he (or anybody else) would like a housing to make a head fixture.
Kevin L
'86 Carrera "Larry"
Old 08-22-2013, 03:06 PM
AlfonsoR's Avatar
Originally Posted by jameshopes View Post
Hello! I am a new member of the forum and joined the forum to share & increase my knowledge through forum discussions.
Welcome!!
"Simplicity is supreme excellence" - James Watt
Old 08-22-2013, 09:10 PM
I would use the old cam tower method. You would get much better precision and repeatability if you mounted a modified cam tower to a face or fixture plate that attaches directly to the spindle.
.003 run out on a 3 jaw chuck is considered "good."
Old 08-22-2013, 09:28 PM
I had a few new OEM Porsche guides sitting around and I ordered a couple of Canyon brand guides to see what was easiest to work with.
I removed the valve guides by threading a bolt into the guide as found here in Henry Schmidt's post Valve Guide Removal
Gord machined the outside of the guides and pressed them into the heads (we tried 2 of each brand). He preferred the Canyon ones because they start with a thiner outside diameter and there is already a step on the outside for setting the installed depth.
I then used a reamer to clean the inside of the guides and fit the valves.
I also preferred the Canyon brand guides. The Porsche guides required quite a bit of reaming to install the valves. The Canyon ones basically needed a quick pass with a reamer to ensure smooth install.
So the 2 new Porsche guides were removed and we used the Canyon ones.
Reaming the guides and a quick re-cut of the seats was easy enough to DIY. I don't have the equipment nor the skills to size the outside of the valve guide prior to installing into the head. I've seen several pictures of cracked heads from what I believe is too much interference fit, here's an example head damage during valve guide replacement
Old 08-22-2013, 11:09 PM
I offered Gord an old cam housing to modify, but he was very happy to make his own adapter. I assure you, he triple checked (if not more) the run out on every head.
Old 08-22-2013, 11:13 PM
Thanks for the great information!
Old 08-26-2013, 04:32 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Working in the film industry for Panavision for long time, I machined many different parts.
Runout on our lathe was less than .0004" (had to be for the camera and lens equipment)...so I benefitted from that when doing anything for myself.
I didn't realise how lucky I was at the time...now I do.
Bob
Bob Hutson
Old 08-26-2013, 09:50 AM
