I have been following this thread with considerable interest as my engine rebuilding is still ahead of me. Thanks to all, especially Henry for sharing their knowledge.
So I have a brand new 1988 Carrera engine case, no serial number, never used that will be the basis for my build. I checked it for the chamfer that is referred to and was surprised that only one side (passenger side) had the chamfers and the other did not. I guess I figured since there are O rings on both sides, both ought to have the chamfer. I can't believe that the factory was that forgetful since they are pretty precise about most things....so, what gives? Is the intent to use beveled washers on one side and the chamfer on the case on the other side? Seems odd... Dennis |
Dir sir (mr self proclaimed expert on everything o-ring and lubricant related), Please explain to the masses, that you have now effectively stirred up, exactly how tensile strength comes into play on an o-ring that has been trapped inside a confined space once everything is sealed/tightened up. Please provide some proof that tensile strength is the mode of failure once the o-rings are installed in an engine. I'm sure that you have detailed reports showing that tensile strength is the only property that people should consider with these o-rings. Please "share" with us "lesser folks" than yourself.
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
Straight shooter
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
The Viton rings are far stronger than they need to be to do the job in my opinion. A loss of some strength seems negligible, especially in a compressed state. As far as attitude Andy, your condescending nature has a way. And instead of private messages, which you seem to be fond of, lets keep the communication out in the open for all to see.
Tell it like it is or don't tell it at all. |
Straight shooter
It may seem condescending if you try to tell me off and it doesn't work out for you. I understand - maybe the first shot fired when you decided to show me a properly cleaned engine in response to my photos showing you are wrong about the chamfer was in jest and I missed it. Otherwise it looks like you attack when you're proven wrong. That's all you between the ears and has nothing to do with me.
I understand that upon dis-assembly, many of these o-rings appear torn (even on never-before-rebuilt engines). More than likely, the tearing occurs when dis-assembling (after the o-ring has stuck to the bolt/washer/case and then is disturbed after service. Most of us REPLACE these o-rings when they are disturbed. If they are installed properly without cutting/pinching them, they will last for a very long time. Tensile strength does not come into play unless you try to stretch them. The o-rings are compressed when installed (under compressive loads not tensile loads). I still have not seen where you "Prove" that one lubricant is better than another. This is a silly thread and you can believe (wrongly) what you want. To the original poster, it's not right to have o-ring squeeze out on these. They can be replaced on one bolt at a time. Try not to turn the bolt or washer, but turn the nut only when tightening. A small chamfer on the case hole can help more easily seat the o-ring. Use a light coat of lubricant of your choice. Good luck!
Straight shooter
Tensile strength is measured in the same way as resistance to tearing which we can agree is the reason for the stronger seals. This makes the value important; we all want strong seals so why knowingly weaken them? That's the question I ask for those of you who fight the information presented here. There's no good reason to knowingly weaken your seals other than because Henry does it. Think about how absolutely silly and cute that looks to an outsider. Free education: http://en.m.wikipedia.org/wiki/Tear_resistance Quote:
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 08-12-2013 at 04:46 AM.. |
For the sake of the original intent of this thread, I abstain from further comment involving Andy. Fact is, unless you're really lucky, Viton O-rings need a chamfer in the case as well as the washer. You can use all the lube you like but if there isn't room for the O-ring it will squeeze out. Consider that if the O-ring doesn't seat with the magic lube mentioned and does squeeze out, the engine must be FULLY disassembled to address the screw-up. The bolts will not come out of the case without removing the cylinders so why in hell would anyone take that chance?
Constitutional Liberal
Andrew, making friends again I see. You are abrasive but not unique.
You're very much like the sports fan, sitting in the third row yelling at a star player claiming to anyone who will listen that "I can do better than that". Of course no one is listening and in your arrogance you miss the fact that you're not even in the game. The sad part is that while you're jumping up and down trying to be noticed, you're ruining the game for everyone else.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Straight shooter
Attacking the messenger doesn't change that the grease in the discussion is a poor choice. I'll save my clowning on your guys for another time.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 08-12-2013 at 07:11 AM.. |
The folks who are spending this thread arguing about who is smarter than the other, will you please take it offline, if possible off planet. It is not helpful.
I remain interested as to the manner in which Porsche intended to do the O rings.....I checked my "scrap" engine case which is a 930/03 (3 litre Euro) and it is chamfered the same way as my new Carrera case. Drivers side is square cut, passenger side is chamfered. Just trying to learn why Porsche would do that. Thanks Dennis |
Oh no another wwest type of character.
Gary Kozun 83 911SC Cabriolet |
When I did my SC, the nut end is what failed not the bolt head end but I put the nut end on the non-chamfered case. I can see how some people might get away with the O-ring mashing up into the threads of the nut end and finding some success but it seems risky to me knowing that a simple case chamfer solves the problem all together.
Try not, Do or Do not
In these situations I tend to minimize the value of "why" given it's impossible to know for sure and deal with the "what" instead. What we know is that they chamfered one side to promote proper o-ring seating and the same issues should apply to the other side as well. Chamfering a case that has no chamfer has no down side. As for the Dow55 compatibility question: Some experts in the field of Viton feel it is compatible giving it combination their highest rating. Elastomers compatibility with chemicals starting with D
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
When I get that far I'll get all the materials and follow the best practice I can find. Thanks again Dennis |
Another page for the three ring binder. Thanks!
Straight shooter
I don't think Dow would even recommend against the combination but they do publish (the manufacturer, not some retailer) data showing a huge loss of strength. Can you get away with that loss? Apparently so for awhile. Some may find that acceptable, and that's their right to choose. That doesn't mean they should attempt to suppress the info and be belligerent when someone suggests alternatives.
Third row heckling at it's best.......once again, why the confrontation? Quote:
Noise quite often obscures the value of a specific discussion.
Straight shooter
Inert alternative: "Introduction to Krytox® Lubricants Discovered in 1959, the polymer that would become known worldwide as DuPont™ Krytox® showed remarkable thermal and oxidative stability.Potential uses envisioned then included lubricant for the MACH 3+ turbine engine, hydraulic oil, rocket gear box lubricant, and even gyroscope oil. In 1963, Krytox® oil was used in a GE engine test for the supersonic transport aircraft.In 1964, new Krytox® PFPE-based grease formulations were developed jointly with the US Navy and the Air Force, resulting in military specification MIL-G-27617, which was developed specifically to cover Krytox®.The first commercial sales of Krytox® were for non-flammable lubricants for the Apollo space program in 1965. Prior to 1981, the only commercially available Krytox® lubricants were aerospace oil and greases.Since then, PFPE-based oils and greases have been adopted across a very wide range of industries and applications.There are PFPE oils and greases for industrial operations, vacuum pump fluids, incidental food contact, automotive uses, reactive gas, and of course, military applications — to name just a few. Today, of course, it’s our well-known trademark for high performance synthetic lubricants used for a variety of applications.Krytox® oils are made from only fluorine, carbon, and oxygen — a mixture of compounds collectively known by many names — including perfluoropolyether (PFPE), perfluoroalkylether (PFAE), and perfluoropolyalkylether (PFPAE).Krytox® perfluorinated oils and greases deliver high performance, perform at wide temperature ranges, and provide superior quality lubrication under extreme conditions in comparison to hydrocarbon alternatives.And, with a global distribution network and world-class technical service, Krytox® is the lubricant of choice for extreme conditions and extreme performance. The use of PTFE as a thickener provides superior chemical and thermal stability to all Krytox® grease product lines.Many greases are also available with additional anti-wear and anti-corrosion additives to further boost performance in critical operations. Krytox® performance lubricants provide superior performance and extended life as lubricants, sealants and dielectrics... Key Benefits The key benefits of Krytox® lubricants include: • Longer lasting lubricant life • Decreased equipment failure and maintenance: warranty claims and replacement costs may be reduced • Increased profits: reduced downtime and maintenance costs • Odorless and colorless • Inert, nontoxic, and non-flammable • Stable in 100% liquid or gaseous oxygen environment • Global distribution • World-class technical service • Chemical, biological, and environmental inertness • Non-toxic and silicone-free formulation • No hazardous VOC materials or chlorine content • Non-hazardous to the atmosphere or ozone layer • Smaller environmental footprint" Accessed 8/12/2013; Source: http://www2.dupont.com/Lubricants/en_US/assets/downloads/Krytox_Overview_LowRes_H-58505-5.pdf
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 08-12-2013 at 04:15 PM.. |
