| Registered Join Date: Mar 2010 Location: New England
				And the pics to prove it....
			So here's what I'm looking at now....
				__________________ - 85 Carrera - | ||
|  08-25-2013, 08:24 PM |
| Registered Join Date: Oct 2001 Location: San Carlos, CA US
			That is rust alright.  Clean that up, install it back into the gear box. Put the fork back in with the pin. Mate the engine and gear box together making sure that the fork engages on the throw out bearing. When the engine is back in the car, slide the big arm up with lots of lube. Engage the omega spring, and snap it back into place. Push the arm as far up as it will go to clear the splines for the smaller lower arm. Slide the lower arm up over splines, snap ring back on, and you are in business. Install the cable, adjust, and done. Don't forget the two orings / dust cover thingies. Not too critical but they are there.
				__________________ Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 | ||
|  08-25-2013, 08:48 PM |
			Yeah I do have the dust cover thing to go back in.  Crap part of it is that I sheared the roll pin in the clutch fork while pounding on the arm.  Now I have to wait until tomorrow to get the pin.  Arrrggg! Thanks all for your help and encouragement!
|  08-25-2013, 08:55 PM |
| Registered |
			Clean the release fork thoroughly and check it for signs of cracking (common problem).
				__________________ Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey | ||
|  08-25-2013, 08:58 PM |
| Registered |
			SOJA... here are some photos of the area you're working on... Rod going onto fork.  The pin that secures the fork to the rod.  The bottom assembly together but for connecting the clutch cable to the hook. The shaft is in it's "resting" position. After putting this together there's an adjustment nut and bolt on the swing arm that rotates freely on the shaft. That needs to be set so there's a "small" gap between the end of the bolt and the fixed arm that rotates the shaft. (Hope this helps you!)
				__________________ Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. | ||
|  08-26-2013, 11:17 AM |
			Karl, Thanks for those pictures. Very helpful... -Matt
|  08-26-2013, 12:47 PM |
| Registered Join Date: Jul 2006 Location: Charlotte, NC
			Only 2 dust seals?  Thought I've seen pics of 3 (depending on year). Todd
				__________________ '81 SC | ||
|  08-26-2013, 04:26 PM |
| Registered |
			I believe there are 3 dust boots.  2-outside and 1-inside.
				__________________ John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | | ||
|  08-26-2013, 06:30 PM |
			Above and below long arm, and then on bottom.of shift fork?
|  08-26-2013, 06:56 PM |
			Before and after pics... I have to say the transmission slapped right on with all the linkage working as it should. Done in under a minute. Thanks again to everyone, your help was indispensable...
|  08-26-2013, 07:15 PM |
| Registered |
Yes TODDU ~
|  08-27-2013, 05:51 AM |
| Registered |
			Matt ... while you've got the trans "available," you might want to consider replacing shifter rod seal. It's costs next to nothing and is easy to replace. Location:  Old seal. Looks like main crank seals but smaller:  Seat is cleaned with brake cleaner and new seal is lubricated on inside ring surface with light touch of high pressure grease. Outside ring surface of seal is dry and clean. With the new seal in hand, this takes a minute or two to replace. New seal is seated with box wrench over shaft and hammered in lightly till it is flush with trans collar.
				__________________ Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 08-27-2013 at 06:24 AM.. Reason: Text refinements ~ | ||
|  08-27-2013, 06:12 AM |
that is a huger garage, complete with dining kit...
|  08-27-2013, 09:09 AM |
It's my hobby lobby.  It doubles as my office/factory too.
|  08-27-2013, 02:14 PM |
