Twin plug heads
What is a realistic $$$ number to convert a set of 2.4 heads to twin plug.
Thanks,
Woody
Old 09-03-2013, 04:21 PM
Air Medal or two
afterburn 549's Avatar
Define who is doing bthe work
You?
or just parts?
pulling the heads and having holes drilled is the cheap part.
Now you have a 1000 ways to go.......no EZ answer
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 09-04-2013, 02:35 AM
Twin plug
If the heads are clean and disassembled we get 500.00 to twin plug includung the valve cover machine work, your choice in 12mm or 14mm
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-04-2013, 05:20 AM
JmuRiz's Avatar
Are different fixtures needed for a 2.4/2.7 than for a 3.0 head? I know someone that has the fixture setup for a 3.0, but not sure if it would work on my 2.7.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 09-04-2013, 06:48 AM
abit off center
cgarr's Avatar
yes
______________________
Craig
G2Performance
Old 09-09-2013, 03:53 PM
JmuRiz's Avatar
Bummer, thanks for the info though.
'64 356SC
‘19 Audi SQ5
Old 09-10-2013, 05:31 AM
