# 8 nose bearing - Difference?
Looking at our host's offereing, I saw:
901-101-138-03-M157 Number 8 Nose Bearing, 911 (1965-73), standard Brand: German - $194.00 901-101-138-03-OEM Number 8 Nose Bearing, 911 (1965-73), standard Brand: Genuine Porsche $142.00 What's the difference in the two. And why is the Porsche price less than aftermarket? Is there something about the more pricey version? Just wondering as I probably should replace mine while I'm having the case worked over by Ollies.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross Last edited by tharbert; 09-19-2013 at 02:10 PM.. |
Schleprock
The M157 is Glyco aftermarket. The OEM is Geniune Porsche in a Porsche box, supplied by Glyco. Theory is the Genuine one is the better one because it's gone thru Porsche's QA/QC. This theory has been proved to be true in years past when the Glyco aftermarket stuff was not looking so good.
If you can get a Genuine cheaper than aftermarket, jump all over that. Because it's typically the other way around. For instance the genuine main bearings (STD) for my 3.0L are about $600 vs. the $200 for Glyco aftermarket!
Kevin L '86 Carrera "Larry" |
