ISpeed2day's Avatar
floor jack that fits my engine adapter?
I have an engine adapter that I bought here on the bird board.
My old jack died and my new jack doesnt have a big enough hole to use the adapter plate.
Where can I get a jack with the older style big hole so I can use the adapter plate.
Old 10-05-2013, 05:22 PM
Look aroound or pay more for the removable base. I bought a floor jack in 2010 and it doesnt have a removable base...but it works on everything else so I still use the old ones but realize the next time I need one, it has to have the removable base.
Bruce
Old 10-05-2013, 07:28 PM
ISpeed2day's Avatar
I have one with a removable base but the hole is too small.
Old 10-06-2013, 05:08 AM
ROW '78 911 Targa
timmy2's Avatar
I made the post on the pelican adapter smaller using a grinder and file. Fits the HF jack with the screw type adjustable base. (after removing the keeper on the screw threads so it comes off). Drilled and tapped a 1/4 bolt in the flat area of the base to secure it.
Works great and I can still use the original adjustable height piece.
Old 10-06-2013, 09:52 AM
johnman001's Avatar
I ran into that problem with the engine adapter that I made. The pin I used was for the jack I had at the time. Each time I get a different jack, I have to go through the ritual of grinding off my pin and turning a new pin on the lathe to fit the new jack.
Sorry to hear your old jack died.
Are you pulling your engine out again?
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 10-10-2013, 10:22 AM
sjf911's Avatar
I bought one in the last couple of years at Sears that had the right size hole. It was the only one I could find in town.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 10-12-2013, 07:43 AM
