3.2 Tin Question
I did a test assembly of my engine tin this evening and discovered this.
FYI, the right side in the pic is from an earlier motor, SC I think. My original was rusted to hell. These two pieces should connect, shouldn't they? Am I missing a small piece for the centre? Thanks
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!) '11 Cayenne Manual, as in it has a clutch :-) (daily driver) '97 BMW Z3 (wife's ride) |
I dug up the pics from the engine drop and found this.
Problem is, I can't remember taking it off or where it went. What the heck is it?
Straight shooter
Probably attached to your wiring harness?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Funny, that's the first place I looked.
The harness has the pass through to go to the starter, and the connection for the oil temp sender, but nothing that looks like the mystery part in the pic.
The TDC sensor isnt used and it does connect to the fuel injection near the gold aircontrol valve. If you cant find it, dont worry about it.
Bruce |
Schleprock
What Bruce said. That thing is a diagnostic sensor that is passive. Meaning you have to activate it with a plug-in tool to use it. That plug Bruce mentioned is underneath the idle stabilizer valve cylinder and has a rubber cap on it. All the years i've fiddled with these cars and discussed them on the forums, I can't recall anybody ever wanting or trying to use it!
Kevin L '86 Carrera "Larry" |
Always Be Fixing Cars
I wondered about this myself when I was taking my motor apart. What does one use the TDC sensor for?
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Not, related but what is the purpose of the black sender pointing at 45' on first pic?
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Temp switch for the heater blower after run fan I believe.
Temperature information back to the brain.
Bruce |
