SC rally motor tear down and questions about cylinders
I finally decided to get my engine torn down for my rally build and so far everything looks good. I plan to hopefully removal all the studs tonight along with the connecting rods. As of now I am interested in what cylinder options I have to run aftermarket 10.5:1 pistons? Initially I planned to have my cylinders sent out and nikasil coated, but i'm unsure if KS cylinders make good candidates for this.
Thoughts?
Old 11-11-2013, 10:00 AM
IXjamesXI's Avatar
I remember reading somewhere on here that KS cylinders in fact make excellent candidates for nikasil replating. Of course don't rely on my advice. I would give EBS a call, or one of the plating companies. It can be done, and it seems very economical when compared w the cost of new cylinders. There's a lot of companies spoken about on here that can replate your cylinders and match them to a new set of JE's at whatever compression ratio you need...
'82 SC Coupe / Pacific Blue
Old 11-11-2013, 10:34 AM
I just spoke with Don at EBS and he echoed your sentiment about the KS parts...
LP
Old 11-11-2013, 10:43 AM
Did he tell you that Carrera cylinders are preferred because the sealing surface is better for 98mm cylinders if you go to 3.2 SS.
Bruce
Old 11-11-2013, 11:58 AM
I have actually been planning to stick with a three liter motor. Should I run the car above three liters, it places me in "group 5" against boosted or large displacement cars. Sticking with a 95mm bore will allow me to run in "Group 2" against most 4 cyl non turbo rally cars.
Old 11-11-2013, 02:08 PM
