BOSCH injection red tap reference
Hello
I am looking for informations (supliers, pictures) about the red tap of mechanical injection.
Thanks in advance
Best
Manu
Old 11-19-2013, 01:23 PM
356RS's Avatar
The Red Cap for the RSR pump is still available from Bosch. Part # 0 457 104 001
The problem is the metal threaded pipe is NLA. You can find some used ones off the early Mercedes MFI pumps. The photos below are not early MB pumps!
Mark Jung
Bend, OR
MFI Werks.com
Old 11-19-2013, 03:32 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec is selling a kit that seals the pump (removes oil supply) that includes a breather that bolts on rather than requiring a hole to be drilled in the housing.
This is important for two reasons.
First you can install the kit without removing the pump from the engine and second you can put the pump back to stock without any tel-tail signs.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-20-2013, 07:11 AM
Thank a lot Mark, Henry
Best
Old 11-20-2013, 12:54 PM
