Head Cleaning
Hi Guys
Quick question. Is it okay to power wash the heads to get all the grease and oil off.
As long as I oil everything afterwards? Heads are going to be bead blasted, but need to have all grease and oil removed first.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 11-19-2013, 08:07 PM
toddu's Avatar
Get 'em hot tanked.....
Todd
'81 SC
Old 11-19-2013, 08:26 PM
Is the machine shop saying you need to clean them? Bead blasting is going to remove everything. Guys I use don't care. They may tumble stuff first. Hot tank for aluminum is an option. I would use carb clean before water.
Old 11-19-2013, 09:22 PM
My shop takes them as removed and the heads come back like new.
Bruce
Old 11-20-2013, 03:14 AM
Guy that is going to bead blast them says they need to have all grease and oil removed.
Old 11-20-2013, 05:28 AM
That's strange. Maybe find someone else?
Old 11-20-2013, 06:37 AM
abit off center
cgarr's Avatar
Head Cleaning
I always wash off the big stuff first before bead blasting just so it doesn't gunk up my beads but never asked a customer to do that.
Is the guy blasting the heads doing the rebuild?
______________________
Craig
G2Performance
Old 11-20-2013, 06:43 AM
E Sully's Avatar
My shop does not like to bead blast combustion area. He is of the opinion that some of the bead media will end up embedded and can cause issues later. He hot tanks them and they come out great.
Ed
1973.5 T
Old 11-20-2013, 06:47 AM
Only the outside surface is being bead blasted. I'll look into hot tanking.
Old 11-20-2013, 09:09 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We disassemble the heads, hot tank then bead blast them. We wire wheel the valve before measuring and solvent clean the springs.
Fresh AD Potters glass bead will not embed in the aluminum so cleaning the head will remove all the glass residue.
Just a side note. All the leaking from the head (oily area by the exhaust ports) is caused by the a lack of head stability exacerbated by Dilivar studs.
Dilivar doing what Dilivar does. Poor / inconsistent clamping pressures
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-20-2013, 03:58 PM
Irrationally exuberant
ChrisBennet's Avatar
I just send my heads to Bob at Anchor Atlantic. He ultrasonically cleans them before he machines them.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-20-2013, 04:14 PM
Hi Henry
Sent you a shopping list on Monday. Need some of your head studs.
Old 11-20-2013, 08:56 PM
My 3.6 heads are with Bob @ Anchor Atlantic right now. RS valves have been installed and should be home in a few days. dropping off the towers for cleaning next.
Old 11-21-2013, 03:03 AM
Sent my to Comp Engineering not cleaned up, other that wiping down. Came back looking like artwork...
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-22-2013, 09:00 AM
It is all about economics.......
With the grease and oil removed from your cylinder heads, the media blasting process will be much shorter and easier. Of course, your guy would surely prefer a much cleaner heads than doing heavily carbon coated heads. Plus the blasting material is less contaminated with cleaner heads. I sent my cylinder heads in a box to the machine shop without any cleaning and get them back like new. Whether I deliver the heads with grease or not, the bill I get is the same. So why bother to clean them.
Tony.
Old 11-24-2013, 04:29 PM
johnman001's Avatar
Please excuse my ignorance, but I have to ask (perhaps it may clarify for others as well)
I was always under the impression that "hot tanking" was for cast iron parts, and that "hot tanking aluminum would eat the aluminum.
Is the reference to "hot tanking" in this thread simply a term used for washing in heated aluminum friendly solvent? That is basically what I do to pre-clean parts that I intend on media blasting. (I try to keep liquids out of my blast cabinet as much as possible).
So, my question is: What is the "hot tank" that is referred to in regards to cleaning aluminum?
Thanks,
John
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 11-25-2013, 10:25 AM
While I'm not an expert, there are two different kinds of "vats", or hot tanks. The traditional one for cast iron parts, like small block chevy blocks and heads, and a lower temp vat for aluminum parts, like many transmission shops use.
Old 11-25-2013, 10:27 PM
I got my heads back to Bob @ Anchor Atlantic yesterday. Great job. He bead blasts them then ultra sonically cleans them. I am very impress with his work and turn around. Heads look brand new.
Easier to quote my last post then copy pics ....
Originally Posted by tocobill View Post
Picked my heads up today from Bob @ Anchor Atlantic. I have to say Im very impressed with the rebuild job and time frame it was completed. Plus hes a super nice guy! He meet me at a location that was convenient for me to drop off and pick up ... pretty much knocked a couple hours off the trip. I had him regrind the seats for 993 RS spec valves and installed the Aasco springs and Ti retainers. He cleaned up the old Na filled OEM valves and measured them for me ... didnt really have to do that either .. just good quality workmanship. Dropped off the cam towers to have cleaned ultrasonically after I got all the gallery plugs removed. Dropped off a bunch of old transmission cases for cleaning to make the trip to southern NJ worth it. The bad of candy hidden in the parts was a nice touch, .
Old 11-26-2013, 08:22 AM
