-   -   Just another 3.0 rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/782171-just-another-3-0-rebuild.html)
lindy 911 01-02-2014 03:23 PM
Mitch, you have to block the passage after the squirter intlet to divert the pressure to the squirter. If you don't block it it will let all the air by-pass the squirter inlet port. Look down the oil passage and you'll see a port going off towards the squiter. Push the rubber hose past that point so it blocks the back side of the passage, then apply air pressure. The "tool" I made is 3/8 rubber hose with a 6mm stud pushed into the end to fatten it up. If Ollies says it's good, it's good but it never hurts to make sure.
http://forums.pelicanparts.com/uploa...1388704756.jpg
http://forums.pelicanparts.com/uploa...1388704785.jpg
Mitch1 01-11-2014 10:25 AM
thanks lindy, got left side squirters to work. #2 might be sticking, but George at Ollie's didn't think it was anything to worry about.
So, got everything cleaned up again and I have some free time tomorrow and Tuesday so I might try to reseal soon.
Started thinking about choices I made and when I would get an opportunity to experience this again. Decided to do a little more to the hardware. Had some stuff cadmium plated by a local shop that has a pretty good reputation. They did a 8 hr post bake on all the parts.
http://forums.pelicanparts.com/uploa...1389464476.jpg
http://forums.pelicanparts.com/uploa...1389464518.jpg
http://forums.pelicanparts.com/uploa...1389464576.jpg
http://forums.pelicanparts.com/uploa...1389464611.jpg
http://forums.pelicanparts.com/uploa...1389464680.jpg
What is the white looking stuff? Aluminum oxidation or left over residue from hot tanking? Tried to scrub it out and it's not coming off.
911 tweaks 01-11-2014 04:17 PM
smart boy there mitch = they did an 8 hr bake after plating = to avoid possible hydrogen embritlement on the newly plated hdwr... carry on...going great...!! bob
Mitch1 01-15-2014 09:22 AM
Thanks Bob. We'll see...
I got some time yesterday and resealed case. Everything seemed to go pretty good. But, as soon as I torqued the last bolt the worry set in. Did I see the oil seals at pump before the case closed? Did I use too much or too little sealant? The prevailing torque nuts seemed to require more torque to get snugged.
Finally, the question I lost sleep over. Got squeeze out of 1184 everywhere except about 1/8 of an inch on either side of the #8 bearing. I really don't want to attempt another reseal at this point, but if I must I will. Should I be concerned? I thought it might be something to do with the #8 o-ring. I'm sure I got sealant up to the edges. Seems like there is a lot or real estate there as far as mating surface.
911 tweaks 01-15-2014 11:20 AM
now is the time to make sure all is ok than to worry for ever as long as you own the engine & car...just think of how profecient you are becoming at this step... :-) not trying to be a wise as^ here but it is what it is...best to double check now than worry for ever...you are not aline I am sure for having to double do a step or so in a build...
Mitch1 01-15-2014 04:52 PM
Took a few pics and got a real close look. Underneath the #8 looks ok. Small amount of squeeze out. Above is about 1/8" to 1/4" of no squeeze out.
http://forums.pelicanparts.com/uploa...1389833312.jpg
under #8
http://forums.pelicanparts.com/uploa...1389833406.jpg
http://forums.pelicanparts.com/uploa...1389833438.jpg
lindy 911 01-16-2014 06:53 AM
I think you're good to go. Mine leaked around the #8 bearing where you are showing good squeeze out. The case joint itself was never an issue. Nice work.
Mitch1 01-16-2014 07:10 AM
Really lindy? I had pretty much convinced myself I need to try it again one more time. I thought maybe the three bond set up there and didn't squeeze out. Even though I only spent 5 min putting it on. That stuff skims over really fast. Or, maybe since the #8 is new it's perfectly round where the case is not and maybe keeping the case from mating as well right next to it.
Actually, there is another possibility. The squeeze out could have wiped off onto my jacket while I was putting in the 10 mm nut in the chain housing. I have a thin .25" line of threebond on my jacket that I kinda wondered how it got there...maybe.
Henry Schmidt 01-16-2014 07:37 AM
It's a hard call. If you get it wrong, there's a lot of back tracking to do. The whole way back.
If you sealed the # 8 main the way we suggest in our case sealing recommendation that comes with our sealing kit, you are probably OK.
The pressure comes for the oil passage/ transition between the case and #8 bearing and if you sealed around that oil passage you will have handled the pressure leak. If there is no sealant between the case halves you could still a weeping.
Your call. It's not an easy one.
Good luck
Mitch1 01-16-2014 07:52 AM
Thanks Henry. Got squeeze out of the 1211 ok. Yeah, I'm gonna be pissed either way. The reseal really isn't a big deal. Just gotta clean everything again.
Mitch1 01-16-2014 09:30 PM
Just got in from garage. Disassembled case and did most of clean-up. I'll post pics tomorrow. Right where the problem area was there was a smear, like the sealant was smeared away at left side exactly at the sharpie mark on the right side case I made for lining up the #8 bearing. I didn't think that ink mark would keep the sealant from adhering. So, might have been a good call to reseal.
On an unrelated issue, when I pulled the crank out several of the right side mains came with it. Stuck to the journals. Are these bearing bad now that I've torqued and untorqued them...twice?
KTL 01-17-2014 07:56 AM
John,
Refresh my memory what the sharpie mark does. If i'm not mistaken, the #8 bearing can only go in one way, so long as you have the dowel pin in the case. I recall there's a scribed mark on the #8 that is visible when it's properly installed in the respective case halve as well?
I suspect the main bearings came out because your assembly lube is pretty sticky? Garage sorta cold? Probably not, being in TX you lucky dog! :D
The mains don't seem to press into the main webs as nearly as tightly as the rod shells do in the rods. I would make sure the back side of the bearings are lightly roughed with some abrasive to give them some "bite" in the webs. Check the fit of the bearings in the webs again & pay attention to how they push into their locations. If they've got some detectable contact pressure, I would say they're OK.
Mitch1 01-17-2014 08:46 AM
Thanks Kevin, the mark was on the case and on #8 to know how far forward the bearing should be to align with the dowel pin.
The assembly lube is really sticky. Brad Penn.
Mitch1 01-25-2014 07:12 PM
Decided I needed a little help. Didn't want to reseal case for a 4th time. Called up my buddies at Zim's and asked Wayne if I could bring my stuff down there and have Darren, the lead Porsche Tech supervise. He said sure. Took all my stuff, case halves with yoke attached, crank assembly, tools, sealants, wipes, lacquer thinner and gloves down to the shop. Set-up and chatted with Darren first thing on Thursday morning. I was still nervous, but not as much as I had been. Decided to use more Threebond 1184 than I did the previous time. Everything went really smooth. Great just having an extra set of hands. (Really great having extra set of experienced hands.) We worked out who would do which operation and after I cleaned everything for the hundred-and-first time. Started. Did everything in about 25 min.
It's been slow as all get out, but I think I am wanting to drag it out a little.
http://forums.pelicanparts.com/uploa...1390705186.jpg
http://forums.pelicanparts.com/uploa...1390705225.jpg
911 tweaks 01-26-2014 06:10 AM
very nice...great decision to ask for help...dont beat yourself up thinking you caved...if anything, you were/are being smart to do it correctly and get more experienced help when you sense you need it...carry on...you are making great progress...!! :-)
Mitch1 05-18-2014 09:05 AM
Haven't updated in a while. Haven't worked on car much lately. Other things more pressing take priority. But, took the day off Friday and decided to work on car. Last sent short block and associated parts to Ed Mullenix to let him complete assembly. I worked on painting engine bay and replacing needed parts.
http://forums.pelicanparts.com/uploa...1400428436.jpg
Short block delivered.
http://forums.pelicanparts.com/uploa...1400428475.jpg
Before
http://forums.pelicanparts.com/uploa...1400428518.jpg
After
http://forums.pelicanparts.com/uploa...1400428562.jpg
Before
http://forums.pelicanparts.com/uploa...1400428614.jpg
After
http://forums.pelicanparts.com/uploa...1400428677.jpg
Before
http://forums.pelicanparts.com/uploa...1400428715.jpg
After
http://forums.pelicanparts.com/uploa...1400428740.jpg
Detailed tunnel and replaced green return fuel line. Replaced vapor recovery small tubing.
Mitch1 05-18-2014 09:23 AM
http://forums.pelicanparts.com/uploa...1400429231.jpg
Oil tank ultrasonicly cleaned by Pacific Oil Cooler installed.
http://forums.pelicanparts.com/uploa...1400429303.jpg
Wheel well painted with base and clear coat. Oil lines installed.
http://forums.pelicanparts.com/uploa...1400429374.jpg
Thermostat rebuilt and flushed by Darren at Zims. Looks beautiful. Darren does great work. Darren also refurbed the oil lines.
http://forums.pelicanparts.com/uploa...1400429488.jpg
Supply and return lines installed. The return line was repaired. I painted both lines and flushed with mineral spirits.
http://forums.pelicanparts.com/uploa...1400429570.jpg
Oil trombone loop. Cleaned and flushed and installed.
http://forums.pelicanparts.com/uploa...1400429652.jpg
First time car has seen daylight in 18 months. Really dusty. Can't wait to get fuchs refurbed. The fake Cup I's are really heavy. The Marine there is Steve with Two Bit Tow. Great guy and they are real reasonable and have a lot of experience with Porsches. (For all you guys in the D/FW area)
http://forums.pelicanparts.com/uploa...1400429793.jpg
Engine getting closer.
http://forums.pelicanparts.com/uploa...1400429833.jpg
http://forums.pelicanparts.com/uploa...1400429862.jpg
Forgot to get a picture of front of engine here. With all the plated hardware at crossbar it really looked great.
Mitch1 05-18-2014 09:36 AM
Did have some unexpected expenses. Ed cleaned and tested all the injectors and recommended replacement. That hurt.
911 tweaks 05-18-2014 10:04 AM
awesome job mitch...now try to keep the pace going so you can complete the car & get her on the road at your earliest convenience...looks great...bob
Mitch1 06-02-2014 09:51 PM
Thanks Bob,
Finally, engine has been reacquainted with the chassis. 1 year to the day. Still not calm yet. Not until all break-in is done and I'm sure there won't be a wiped a cam lobe or spun bearing. (Man, when does that anxiety stop?) Just drove it briefly on Saturday when I picked it up. Had a sick kid at home so didn't really feel like celebrating and couldn't drive it home from Ed's shop because I was working all day Saturday. Had a flat bed (Steve) come and get it. Ed drove it a couple of days after initial start-up and break in. No strange noises. Good oil pressure and no leaks...yet. So far, it looks like I may have done a good job on the case sealing. (knock on wood). Going to do something Friday I haven't done since buying it. Wash it. Probably put 50 or so miles on it to get to a 100 varying the RPM's and change the oil again.
http://forums.pelicanparts.com/uploa...1401770370.jpg
http://forums.pelicanparts.com/uploa...1401770404.jpg
