Head Cleaning
![]() Hi Guys Quick question. Is it okay to power wash the heads to get all the grease and oil off. As long as I oil everything afterwards? Heads are going to be bead blasted, but need to have all grease and oil removed first. ![]()
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. |
Get 'em hot tanked.....
Todd
'81 SC |
Is the machine shop saying you need to clean them? Bead blasting is going to remove everything. Guys I use don't care. They may tumble stuff first. Hot tank for aluminum is an option. I would use carb clean before water.
My shop takes them as removed and the heads come back like new.
Bruce |
Guy that is going to bead blast them says they need to have all grease and oil removed.
That's strange. Maybe find someone else?
abit off center
Head Cleaning
I always wash off the big stuff first before bead blasting just so it doesn't gunk up my beads but never asked a customer to do that.
Is the guy blasting the heads doing the rebuild?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
My shop does not like to bead blast combustion area. He is of the opinion that some of the bead media will end up embedded and can cause issues later. He hot tanks them and they come out great.
Ed 1973.5 T |
Only the outside surface is being bead blasted. I'll look into hot tanking.
Try not, Do or Do not
We disassemble the heads, hot tank then bead blast them. We wire wheel the valve before measuring and solvent clean the springs.
Fresh AD Potters glass bead will not embed in the aluminum so cleaning the head will remove all the glass residue. Just a side note. All the leaking from the head (oily area by the exhaust ports) is caused by the a lack of head stability exacerbated by Dilivar studs. Dilivar doing what Dilivar does. Poor / inconsistent clamping pressures
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Irrationally exuberant
I just send my heads to Bob at Anchor Atlantic. He ultrasonically cleans them before he machines them.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Hi Henry
Sent you a shopping list on Monday. Need some of your head studs.
My 3.6 heads are with Bob @ Anchor Atlantic right now. RS valves have been installed and should be home in a few days. dropping off the towers for cleaning next.
Sent my to Comp Engineering not cleaned up, other that wiping down. Came back looking like artwork...
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
It is all about economics.......
Tony. |
Please excuse my ignorance, but I have to ask (perhaps it may clarify for others as well)
I was always under the impression that "hot tanking" was for cast iron parts, and that "hot tanking aluminum would eat the aluminum. Is the reference to "hot tanking" in this thread simply a term used for washing in heated aluminum friendly solvent? That is basically what I do to pre-clean parts that I intend on media blasting. (I try to keep liquids out of my blast cabinet as much as possible). So, my question is: What is the "hot tank" that is referred to in regards to cleaning aluminum? Thanks, John
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
While I'm not an expert, there are two different kinds of "vats", or hot tanks. The traditional one for cast iron parts, like small block chevy blocks and heads, and a lower temp vat for aluminum parts, like many transmission shops use.
I got my heads back to Bob @ Anchor Atlantic yesterday. Great job. He bead blasts them then ultra sonically cleans them. I am very impress with his work and turn around. Heads look brand new.
Easier to quote my last post then copy pics .... Quote:
