what is this, its leaking,...what O ring do I need
Old 12-07-2013, 06:55 PM
I believe that is the set bolt for the spray bar in the cam tower. 6mm copper or alum crush washer.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 12-07-2013, 07:42 PM
They are usually installed very tight as they are 10mm fine thread.
Aluminum washer
Bruce
Old 12-08-2013, 03:15 AM
Aluminum washer
Bruce
I just installed some heat exchangers and exhaust and could never find my oil leak coming from the rear right side of the engine. Was a pretty decent leak. About a two inch spot on garage floor after driving.
I cleaned everything off with brake clean, removed right side engine tin, HAHA bolt was finger tight and no crush washer. I started engine and just watched as it pissed everywhere.
So happy I was able to track this down.
Old 12-08-2013, 11:27 AM
is there a torque setting for this bolt?
Old 12-08-2013, 11:28 AM
Tight enough to crush the washer
Bruce
Old 12-08-2013, 02:15 PM
The spec is about 40Nm but I agree that it should be just tight enough to crush the washer, and no more, It is to stop a leak and not to hold up any substantial weight. If you use a new washer, you will feel it when it is being crushed and stop.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-08-2013, 06:41 PM
I suspect I may have the same situation with my newly rebuilt 81sc motor that has been spotting a few drops on my floor just under that same bolt position. I know there are a few other possibilities, but I believe the chances are good that this bolt and washer were not appropriately attended to.
What location (relative to the suspect bolt) did you find the oil drops on your floor?
Where else on the motor did you see this leak migrating to (and confusing your diagnosis!)?
Lastly, if this is in fact the cam spray-bar mounting bolt, would completely removing it (to replace the washer) while the engine is still installed, cause any internal issues with the spray bar?
Thanks for posting this discovery as it may indeed relieve me from years of grumbling!
Old 12-08-2013, 07:43 PM
The bolt has a point that locates the spray bar correctly and the spray bar wont turn without a concentrated effort.
Pull the bolt, install washer and replace. Tighten to crush washer.
Bruce
Old 12-09-2013, 04:54 AM
I could not figure this out, it was a good size spot left on garage floor after driving. heat exchangers was soaked, top right side engine tin was covered, oil cooler was covered, right side wheel well was covered...basically the whole right side of the car...
I had replaced both upper and lower valve cover gaskets, and oil cooler rings, and nothing. still leaking.
I took everything apart while I was in there installing new heat exchangers. I left the right side engine tin off the car. Sprayed everything with two cans of brake clean so it was spotless. Fired up the car and the thing was PISSING, about a drop every two seconds. That bolt was literally finger tight with NO washer.
I put new crusher washer in today, fired up, all good. I just hope the added oil pressure doesnt cause a leak somewhere else now
Old 12-09-2013, 03:15 PM
Nice! one step at a time sir, one step at a time....
Thanks for responding, I will look into mine.
Cheers,
Bill
Old 12-09-2013, 08:29 PM
