Viton valve seals
Hi, is this the best valve seal you can put in an '87 911 turbo motor? There's a lot of them to choose from.
This is from the pelican catalog and it says it's a viton valve seal for a 3.3 liter 1987 911 turbo among other motors
If it's not the best to use which one is and where do you get them?
thanks.
Part #: 928-104-193-12-M213
Brand: D P H
$2.25
Old 01-27-2014, 12:27 PM
Certified Pre-Owned
BGCarrera32's Avatar
I'm not sure but I have used those on my non-turbo Carrera motor and I was not impressed with the quality. They were a pain to tap on to the valve guide as well. I went with Victor Reinz viton this time around and found the molded part quality much better and the install easier.
I have heard that guys will run teflon seals in turbo motors and even add a slight notch or groove to the seals on the exhaust side to allow some extra oil on to the valve.
'84 Carrera Coupe
Old 01-27-2014, 03:55 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We run the Teflon seals to promote better lubrication. The Viton seals a little too well in my opinion to allow the valve guide/ stem to survive the heat demands of the turbo engine.
There seems to be a toss up as to sealing vs wear. A puff of smoke vs longer valve stem life.
In racing Turbo engines we often exclude the seal altogether.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-28-2014, 06:45 AM
Puny Bird
Mark Henry's Avatar
Hi Henry
If viton would you cut a v-notch in them?
For turbo?
How about NA?
The seals in your engine kits are they teflon or the viton?
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-29-2014, 05:53 PM
Originally Posted by Mark Henry View Post
Hi Henry
For turbo?
How about NA?
We use Teflon seals on all turbos (that we use seals on) and early engines.
On late model (for us that's 3.0 -3.6) we use Viton without modifying them.
The Wrightwood Racing gaskets set we sell are custom made to order and can have either type of valve stem seal.
Henry Schmidt
Ph: 760-728-3062
Old 01-30-2014, 07:10 AM
