found a silicone type of glue in block? is this stock?
Hi Guys , should there be silicone at these spots?
Erick
Old 02-10-2014, 02:06 PM
Try not, Do or Do not
Henry Schmidt's Avatar
These casting areas were left unsealed from the factory when a pressure cast aluminum case was first released and then sealant was added after leaks were discovered.
We use Loctite Hysol but JB Weld is very similar.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-10-2014, 02:27 PM
Thanks for the fast reply
Was this added at the factory, the car is a 89 turbo
Old 02-10-2014, 02:51 PM
Project Addicted
Yup.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 02-10-2014, 05:55 PM
Should there be JB weld used inside the case? On another thread I thought others were against it? In case is were to break off and get caught in the oil screen???
Old 02-12-2014, 08:44 PM
Good point Justin
Can you use JB weld on the inside?
Old 02-13-2014, 08:21 PM
