found a silicone type of glue in block? is this stock?
Hi Guys , should there be silicone at these spots?
Thanks Erick ![]()
Try not, Do or Do not
These casting areas were left unsealed from the factory when a pressure cast aluminum case was first released and then sealant was added after leaks were discovered.
We use Loctite Hysol but JB Weld is very similar.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks for the fast reply
Was this added at the factory, the car is a 89 turbo |
Project Addicted
Yup.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
Should there be JB weld used inside the case? On another thread I thought others were against it? In case is were to break off and get caught in the oil screen???
Good point Justin
Can you use JB weld on the inside? Thanks |
