Englene number
I have bought an 2.7 rebuild MFI engine with number 612...5 and engine stamped 911/91 which indicates a 173 1/2 type, but the nummer series indicates a US 1972 T CIS So what is wrong? 911/91 is casted but engine nr. Seems tampered with or maybee manuelle marked, can Someone explain.
Regards lexn
Old 02-12-2014, 02:25 PM
pors1968's Avatar
Engine number612 is 1972 engine 911/91 cis us 73 but engine 612..... and 911/61 72T
Old 02-12-2014, 03:18 PM
banalytic
panama911's Avatar
According to some other forum... 911/91 went from 6133001 to 6136092.
It shouldn't be 2.7, shouldn't be MFI either; your case (911/91) was supposed to be a US 2.4 T CIS.
Old 02-12-2014, 03:28 PM
pors1968's Avatar
911/91 is a 1973 case but 612 is 72T case kind odd.
Old 02-12-2014, 03:55 PM
Are you sure it's not 911/51 or 911/61?
That would make sense for a US 72T with MFI 5speed or sporto
otherwise I would guess the number has been re-stamped
Old 02-12-2014, 06:22 PM
Try not, Do or Do not
Henry Schmidt's Avatar
A huge number of 2.7 engines exploded during their early lives do to over heating.
Although not all but some of the 73 cases were 7R castings with a 2.4 spigot size.
As a 7R case, it makes a great replacement case for building a 2.7. All that is needed is to bore the spigot from 94mm (?) to 97mm if memory serve me.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-12-2014, 06:37 PM
Yes I´m quite sure that is 911/91 but the engine number looks a bit odd, have heard that is a star fore and after, but not on this, what should be the reason for a false wrong number? other than stupidity.
Old 02-13-2014, 01:11 AM
pors1968's Avatar
Take a picture of engine and serial number will be easier to speculate.
Old 02-13-2014, 03:28 AM
Engine No.
911/91 looks ok but the other one ?
Old 02-13-2014, 09:36 AM
Constitutional Liberal
Turbo_pro's Avatar
Serial number is a restamp. Might be a dealer restamp but generally they use German number stamps.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 02-13-2014, 10:40 AM
pors1968's Avatar
It look like dealer restamp .Number look same size on serial and internal.
Old 02-13-2014, 03:07 PM
Numbers
Just found more nubers on my case 901,101,102,3R this indicates a 2.2 case, haven´t taken it apart because it runs fine with no oil spill, but I bought it as a 2.7 rebuild, but is this possible with a 3R case?
No I got a lot of different series numbers 911/91, 6120015 and 901.101.102.3R what should I think this is, maybee take it all apart.
Old 02-17-2014, 04:00 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Oui, no "*" on either side of the serial and the "/" on the engine type is rather long
Who Will Live... Will See
Old 02-17-2014, 04:29 PM
pors1968's Avatar
2R and 3R =70 -71 2.2 3R 4R 2.4 72-73 you have to look both side
Numbers
Other side is 901.101.101.4R and what is that, can anybody tell an amatør what type of block this is, I am a bit confused, have patient please
Old 02-18-2014, 07:21 AM
pors1968's Avatar
Like post 14 3R and 4R is 72-73 that goes whith serial number 6120015 1972case 2.4
Old 02-18-2014, 07:50 AM
Numbers
Ok thanks then I understand, I have a rebuild 2.4 Us case with 2.7 syl and perhaps a reinforced case, maybee reasons for the 911/91 stamping.
Old 02-18-2014, 09:06 AM
pors1968's Avatar
I think 911/91 they stamp is 9 is upside down should 911/61 the 9 is error whith case number 6120015 but you may have 2.7 barrel whith 2.4 crank is a 2.7L
Old 02-18-2014, 09:51 AM
E Sully's Avatar
Neither the 911/91 or the serial number look anything like original factory.
Ed
1973.5 T
Old 02-18-2014, 11:36 AM
pors1968's Avatar
Agree it a restamp by who knows.Like post 11and 13
Old 02-18-2014, 02:43 PM
