Yes, velocity stacks are needed.
Tell it like it is or don't tell it at all. |
Schleprock
Agreed. They are similar to the chokes inside the carb throats in that they tune the airflow into the carbs. They are basically like the main chokes/venturis in that they allow the air to be gathered and accelerated into the throat. The air is accelerated by the diameter transition. Going from large to smaller is the venturi effect which accelerates the flow.
Kevin L '86 Carrera "Larry" |
83 911 Production Cab #10
https://www.google.ca/#q=venturi+effect
And since I like the look of them I went from: ![]() to this; ![]() to this; and ![]() finally finish with that ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Very nice. I think i'll try and try and get my engine to work before blinging it up more.
When I sent the first picture around I got a few, but is it working!!!
I think from a pure air flow perspective, the rain hat option or the K&N will flow much more air. The stacks with the little filters in each look very restrictive to me. Consider the total surface area of the K&N, then compare it to the total surface area of the three little filters. Also, make sure whatever choice you use that there is ample room between the top of the stack and the bottom of the air cleaner. The setups you show have been known to be too close and restrict air flow.
Schleprock
I think the best choice for a dry environment is the ITG filter setup. Plenty of flow AND filtration.
ITG air filter kit for PMO [9312-41] - $279.00 : Clewett Engineering, The complete solution for ignition & fuel injection The K&N is a nice fit and quite common. But the filters are know to allow too much dirt to pass the filter.
I set up the throttle / accelerator linkage as good as possible using the original CIS linkage, however I think it's still too long even though I've adjusted / shortened every rod from the pedal to the intake manifold linkage pivot / bell crank.
I've read that the top of the the bell crank / pivot should be nearly parallel to the deck - mine is significantly angled down toward the rear of the vehicle: ![]() I think it will work for start up but based on my research, the current set up may result in uneven throttle response. I searched for a used transmission mounted bell crank made for carburetors but didn't turn any up; same for the early linkage rod that goes from the trans to the intake manifold - as such I think I need to shorten one of the linkage rods. Steve W recommends removing ~ 1" from the rod that goes from the trans to the intake manifold. Anyone ever do this, and if so, did you just cut the end off and re-thread the rod? Thanks, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Gordo
You sure that's not an inch off the rod from the peddle to the tranny bellcrank? Post a WTB. Within a day I was able to source a bellcrank and an early rod from tranny to manifold. Still need a slight adjustment, but smooth operation and WOT is achievable. Todd
'81 SC |
In my kit the pivot plate supply by PMO had 2 place to mount the ball, one place for high throttle and one for low one. As luck would have it, I pick the wrong hole when I first assemble it.
R Gruppe #111 Early S Registry #235 res ipsa loquitur |
Electromotive XDi
I don't know if I have any photos - but I mounted the XDi controller under the passenger seat.
The link has info on how I wired it in: Engine Harness / Multi-pin Connector for Carb Conversion '83 SC Good luck, Gordo
Thanks, Gordo. Good links on your link too!
If you ever get lost in the Shenandoah Valley, look me up.
AirBorne!
subscribed
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
Driver's License Owner
Can someone tell me which early bellcrank to use at the transmission? There is one version from 1965-1969 and another from 1969-1972. Thanks!
Thanks -- Chuck 1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700 |
Puny Bird
Jealous...this would be the perfect upgrade for my 3.0 twinplug with 40's.
But then I'd have to upgrade my headers, etc, plus I'm from Canada so balls in it would cost around $10K. I guess I could get a couple large for the fresh 40's.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
46 PMOs
I just purchased a pair 46mm PMOs from Rothsport. Cant wait to get them. Just rebuilt motor 2.8 with J&E Pistons 9:5.1, MOD S cams, ported heads 41/35, Rarelyl8 headers 1.5 OD and M&K GT3 sport muffler. 7:31 gear ratio.
Interested to hear how you make out with the headers. I had them for a hot second but was told the primaries were too short for carbs. Have mixed feelings about my current headers.
Todd
'81 SC |
Brian makes his headers custom to your motor specs. I will let you know.
Thread Tools | |
Rate This Thread | |
