Fresh rebuild now runs... And leaks oil
Top of the motor, above engine tin appears dry. I have not yet looked under the shroud. Bottom of the engine on left bank is wet. Losing about a drop a second or so at idle. The leak appears to come from above the air baffles against the cylinders. Oil drips are forming at the entire length of the baffle. In the 993 this is a single aluminum piece.
It seems likely it is a through bolt o ring leak. I cannot see any through bolts so this is only a hypothesis at this point. If it is a through bolt oring that was not seated properly but is otherwise Ok ie not shredded from install, would a hard run up the highway potentially push the o ring into proper position? I'm wondering if it wasn't seated on the thickened part as it should be and is actually on the skinny part of the bolt. Other ideas are helpful if you think I am on the wrong track Thanks Jim |
If it leaks, take it apart until you find the leak. A hard run up the highway will just make it leak more and the airflow will move the oil to parts of the motor it's NOT leaking from, making it harder to find the leak.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Confirmed with a bore scope, two, possibly three leaking through bolts. On the bright side, another weekend in the garage playing with the car!
Straight shooter
Sorry to hear of the tough luck and need to go back in.
When you replace the o-rings try to take a look at the alternative greases that are available to dress them. Some popular greases that have been/still are widely distributed actually weaken the ring.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I dont think it was anything we coated the o ring with, we used motor oil. I suspect one was pushed too far down on the side with the nut. I'll know tomorrow and will post my findings.
Might want to use the green viton ones instead of the soft blue ones.
-Andy
72 Carrera RS replica, Spec 911 racer |
Green Viton and Silicone in kit...Thank you Henry Supertec for a leak free engine on my first rebuild!!....zero leaks........sealants and advice...great forum!
I recall that Henry stated that the blue orings were especially for the 3.6 engines as they have a different configuration on each end of the through bolts. The orings fit into a recess and a stepped or top-hat washer goes on top. I have a 3.6 with leaky through-bolts that I'm tearing into before too long, so I wonder if anyone has had success with the green orings with these engines, or if you have to use the softer blue orings.
Try not, Do or Do not
For those unfamiliar with Dow 55, a few of the military applications are listed below. Although case through bolt o-rings function in a relatively low pressure environment, many of the mil spec applications are high pressure (IE: hydraulics) proving Dow 55 capable of providing exceptional service in severe environments. The military has been testing Dow 55 o-ring lubricant for decades and still calls for it's use. WPN SYS ID WPN SYS SVC WEAPON SYSTEM 03 F Aim Sidewinder Missile Systems (9P/L/M/X) 04 F Aircraft, Stratofortress B-52 05 F Aircraft, Stratolifter C/KC-135 10 N Aircraft, Tomcat F-14 16 N Aircraft, Viking S-3B 19 F Aircraft, Eagle F-15 25 F Aircraft, Awacs, E-3A 26 F Aircraft, F-16 35 A Howitzer, 155MM, M-198 39 N Helicopter, sea King H-3 43 N Aircraft, Hornet F/A-18 44 N Helicopter, Lamps Mark III, SH-60B 48 N Helicopter, Utility/Search and Recovery UH-1N 52 N TA-4J Aircraft 55 N Aircraft, Harrier AV-8B 58 N Aircraft, Hercules C-130F 59 N Aircraft, Hercules KC-130 63 N Aircraft, Orion P-3 99 N Missile System, Aegis Surface (Sms) Mk 7 B2 N Littoral Combat Ship, Flight 0 BE N Missile, All-Weather Anti-Ship, Harpoon (AGM-84) C4 N Helicopter, H1 All Versions CP N Helicopter, Advance Attack, AH-1W ER N Helicopter, Carrier Based Asw, SH-60F JC N Fms - Kidd Class Ddg JD N Arleigh Burke Class Ddg JR N Fms - Knox Class Ff PS A SG-1139/G, Digital Data Generator UC A Mask, Protective, Gen/Spl Purpose (M40, M17, M9 Series) YJ N Virginia Class Submarine, SSN-774 YL N Helicopter, Seahawk, H-60 Z9 N Aircraft, FA-18, a - D, E/F, G (Growler) ZD N LPD-17 Class Amphibious Transport Dock
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Straight shooter
Pay attention to the grease you're using. There are VERY POPULAR greases that retailers provide that weaken the o-ring and continue to do so at operating temperatures. Many of these retailers throw around words in defense of their sale of these products such as 'superior', 'perfect', 'supposed to weaken, it's okay' or like McDonalds: 'billions served' but refuse to acknowledge there are alternatives without the same inherent flaw.
Schleprock
Really? We're going to start the thru-bolt o-ring lubricant debate again? Wow.
Oil itself actually weakens o-rings too. What alternative engine lubricant should we use to avoid that happening?
Kevin L '86 Carrera "Larry" |
Straight shooter
We might be able to avoid it... I believe op was confirming the rings were installed properly. If they were then we can go ahead with the Inert Dupont option v. Reactive Dow Corning... round 17.
Schleprock
I think a more appropriate picture for the massive ability you possess to hold a grudge should be:
![]() LOL
Straight shooter
All kidding aside, I don't care who sells it but believe consumers should be educated so they can choose with all information before them. Speaking of which, big GMO labeling progress in Vermont. Looks like they'll be the first state to pass it as law.
Is someone kidding?
Tell it like it is or don't tell it at all. |
Straight shooter
Troops massing on the sidelines of the thread pending OP discovery.
Pelican Parts Reporters caught up with one troop without insignia named Lindy. Here's what he had to say: "I'm not here to fight. I'm here to help my brothers." ![]()
Location: 24 miles from Lime Rock Park. 1 light, 8 Horse Farms, 114 Turns
Huh?
Schleprock
The debate over thru-bolt o-ring lubricant and its effect on the o-rings took place in the thread linked below and that's where the jabs between Laprkritis and I are coming from.
Your opinion wanted. Green bolt through viton o-rings with rtv
We replaced all the orings and found 1 torn completely through and one slightly shredded. The one torn through was the one I could see clearly leaking (I used a borescope). I think it was not properly seated initially and the washer pinched it when the nut was torqued. The one that was slightly shredded was right next to it, I cannot be sure if it was damaged on install or removal.
Straight shooter
