Weber 40IDA gushing gas - help!
Did I do something stupid?
I just put the rebuilt motor back in the car and in have many issues.
One (minor) one is that the car was leaking fuel where shown below with arrow 'A'.
To try and get more clamp on the sealing washers I added a chamfer as shown.
Now when I turn on teh fuel pump fuel gushes up through here..
Why?
I didn't change the float settings or anything else...
Sam
1971 911T 3.0SC (Jezebel) (Work in progress)
1971 911 Gulf relplica (Gloria) (SOLD )
2013 Tacoma TRD - Expedition ready
2010 BMW R1200 GSA
Old 04-19-2014, 03:11 PM
abit off center
cgarr's Avatar
Floats are not shutting off the fuel for some reason, those tubes are vents
How much fuel pressure are you running?
______________________
Craig
G2Performance
Old 04-19-2014, 04:15 PM
Not sure and cant start it to read the in line gauge now without a 2" plume of gas....
But it is the same as it was 15 minutes earlier before I added that chamfer and it didn't vent there. The other carb is still fine.
Can't figure it out.
Sam
2010 BMW R1200 GSA
Old 04-19-2014, 04:54 PM
porschetub's Avatar
And theres the answer
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 04-19-2014, 04:56 PM
abit off center
cgarr's Avatar
Did some of that metal from the chamfer go into the needle and seat?
Craig
G2Performance
Old 04-19-2014, 05:41 PM
Walt Fricke's Avatar
How about you pull the top of the fractious carb off, and pull the float valves out. You can check/clean them to see if you got something in them, and check the passages while you are at it.
With the top off, but the fuel intake still attached, you could use small C clamps to hold the float valves full up, and then pressurize the system, to see if that works. Carefully.
I'd be perplexed, too, if this happened to me, though I suspect I'd have just replaced the crush washer that was leaking to see if that solved the problem.
Is a rubber(like) gasket normal in this application, rather than an aluminum or copper crush washer? I can't tell from looking at a parts diagram.
Old 04-19-2014, 09:43 PM
Thanks, will do.
Had replaced the crush washer to no avail...
Sam
2010 BMW R1200 GSA
Old 04-20-2014, 05:20 AM
Found it.
I must have put the top plate on at an angle. in doing so I bent the vertical tab on the float (the one at 90 Degrees to the tab you adjust float height with). This ended up at about a 20 degree angle from the adjustment tab and as such got hung up on the plunger body above.
This stopped the float raising enough to move the internal plunger and shut off the fuel.
Lesson learned.....always drop the top plate straight down on the body....
(Excuse poor Sunday night sketches...)
Sam
2010 BMW R1200 GSA
Old 04-20-2014, 07:23 PM
'Grats!
It's been a while, but I'm pretty sure float height adjustment is done with shims under the float valve.
Old 04-20-2014, 07:55 PM
Typically you use shims for float adjustment, because you can do that without taking the top off the carb when you are checking or adjusting the level with a sight gauge. I even have used a rubber washer, as that allowed me to adjust without replacing shims.
But setting the carb up includes a measurement of the height of the tab on the float which pushes on the needle/ball/Gorse valve's tip, compared with a reference point. At least, if you are having issues you'd check this, because there is a spec for it. So bending a tab can be part of the deal. Those were fine diagrams.
Old 04-20-2014, 10:08 PM
Adjustment
Got this from a vendor - this is how I do mine. I was not adjusting floats when this happened though - just had the barb open and caused the issue inadvertently when closing it up apparently.
Sam
2010 BMW R1200 GSA
Old 04-21-2014, 05:58 AM
Here you can see the bent tab and the semi-circular witness mark where it was catching on the plunger body and stopping the float raising to shut off gas.
Sam
2010 BMW R1200 GSA
Old 04-21-2014, 09:16 AM
