Smoke after rebuilt
Hi guys did a full rebuilt ran the car for 5 min only. No noise car sounds great
One week later restarted and the car has a little smoke is this normal until I do the breaking in?
Erick
Old 05-07-2014, 06:49 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Smoke colour? and smell if distinctive.
Who Will Live... Will See
Old 05-07-2014, 07:25 PM
Did you replace the cams or rockers? Usually a 20 minute run in at 2000 rpms is recommended on a fresh build. Then drain and replace the oil. If you only ran it for five minutes then you likely didn't even warm the engine enough.
That said, if you are just getting a puff of smoke on startup than it is likely normal. If you are getting continuous smoke then it can be a number of things from the rings not seating to an overfill, etc.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 05-08-2014, 12:50 AM
Straight shooter
Lapkritis's Avatar
Go find your favorite road and bed those rings in. It's the most exciting part of any engine build in my book.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 05-08-2014, 09:39 AM
