-   -   Engine Harness / Multi-pin Connector for Carb Conversion '83 SC (http://forums.pelicanparts.com/911-engine-rebuilding-forum/812816-engine-harness-multi-pin-connector-carb-conversion-83-sc.html)
Gordo2 05-23-2014 08:02 PM
Folks,
I've decided to give it a DIY go and make an engine harness for my PMO conversion (although it is quite tempting to have Pelican Timmy2 - Dennis build me a harness):
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/740894-building-sc-mid-year-engine-harnesses.html
I'm considering ditching the old 14 Pin connectors and substituting with a modern weather proof connector. Also, I haven't found a source for the female 14 pin connector and the male is ~ $50...
Meanwhile, the number of alternative multi-pin connector options are mind-boggling...
I've kind of narrowed in on this one (understand I will require/have 8 of the 14 circuits remaining with the carb conversion):
http://forums.pelicanparts.com/uploa...1400900151.jpg
8 POSITION MOUNT FLANGE M150L EXTERNAL 19429-0029 - 38452
Any thoughts or considerations toward going this route?
Thanks,
Gordo
Edit - rats... meant to post on the Tech Forum.
sjf911 05-23-2014 08:34 PM
You need to look closely at the pin size as it relates to current capacity and wire size. I have 1 Weather Pack 22 pin bulkhead connector and 2 Deutsch 12 pin bulkhead connectors and still used the original 14 pin connector. Of all of the connector types I have used and have in the car, I found the Metri-Pack or GT series to be the most flexible and easiest to use.
timmy2 05-25-2014 01:24 AM
PM me and I will give you the part numbers for the female 14 pin connector. Top, bottom and the pins.
All available from Porsche for about $30 total.
Or, I could build you a carb style harness this weekend and you would have it next week! :)
Gordo2 05-25-2014 08:09 PM
Thanks Dennis
Originally Posted by timmy2 (Post 8082221)
... Or, I could build you a carb style harness this weekend and you would have it next week! :)
Ha - you haven't been taking to my brother have you ;)? He's been giving me all sorts of greif telling me to get it on the road already...
Without a doubt, the more I look into it - the more I appreciate & respect the high quality harnesses you make.
Meanwhile, I've warmed to the idea of making my own engine harness for the following reasons:
- In concept, the harness should be relatively simple since I've gone to carbs and removed nearly all of the ancillary electrical components / circuits. In concept... execution is proving otherwise as I am a research junkie...
- I'm looking at mounting the connection toward the front of the engine (near the location where the CIS connector mounts) as opposed to the standard driver's side location. I like this idea from the standpoint that it will reduce the visibility of the harness (i.e. I like the idea / look of a "naked" engine). Somewhat of a non-standard harness approach.
- I have a few items that I may decide to integrate into the harness as I dig into them (XDi ignition, Wideband sensor wiring etc.). As such, thus far I can't quite put my finger on what I want.
- The OEM 14 pin connector design seems outdated (along with the rest of the car's wiring in general...), hence my consideration toward the Molex or other connectors.
- I like the idea that taking on the harness will give me a better understanding of everything that connects to the engine.
Greatly appreciate the offer, will take you up on the 14 Pin connector source (PM sent) as a back up in case my search for an alternative doesn't pan out.
Gordo
timmy2 05-25-2014 11:02 PM
Meant to post this earlier, don't know where it went???
14 pin cover 99965243040
14 pin base 99965243640
Female pins 99965237612
Cover and base part numbers may be swapped, but you need both anyways.
PM replied to.
No, your brother didn't call me! :)
Gordo2 05-28-2014 08:33 PM
I'm All In
Too many options...
Now considering integrating the Electromotive magnetic pick-up and coil pack wire harnesses and remaining circuits into a single, circular multi-pin connector like this:
http://forums.pelicanparts.com/uploa...1401333717.jpg
This config would provide a clean, solid single connection for the all engine related components.
Meanwhile I'm debating the drawback of having everything harnessed together from a future troubleshooting perspective:
- Having a stand alone wiring harness for the Electromotive components, zip tied to a second harness containing the required engine sensors/controls (oil press, temp etc)
As I debate options - I went all in and started to unfurl the chassis harness.
http://forums.pelicanparts.com/uploa...1401333921.jpg
No matter what approach I finally decide upon, I plan to separate power wires (like the large / 12ga yellow starter relay) to their own connector.
Gordo
Walt Fricke 05-28-2014 11:19 PM
I'd say weatherproofing is not really necessary. The 14 pin connectors don't generally go bad, and they aren't other than being up away from tire splash.
I assume you are going with Electromotive ignition? With carbs, I ran the oil pressure, oil temperature, idiot light, and the alternator warning light wires, along with positive and ground for two EGT probes to a 6 pin white plastic Molex mounted on the shock cross member. Its connector mate from the engine plugged into it. Molex is easy to work with, as you can crimp (and solder) the wires directly to the connectors, and then push them into place. Your first picture looks like a nice option, easy to mount, if it assembles in this way. The spiffy round ones in a later picture raise the question of how wires attach - butt connectors to wires it comes with, soldering bare ends into small, in place holes, or something easier.
But if you mount the Electromotive stuff on the chassis, you avoid all that. Just pull the plug wires and you are done with that part of it. Chances are you are going to pull the plugs as part of whatever you are doing with the engine out anyway.
The starter relay wire you can run straight to the starter, no connector needed beyond what it already has. When removing the transmission you have to pull the main cable off of this anyway, and to remove the engine you need to pull the alternator B+ off the starter, so nothing lost there.
I bought an audio 4 pin, screw sleeve to hold the halves together, connector, and mounted it in a bracket on the left frame rail. It is indexed, and I cut the Electromotive sensor wire and soldered it into this connector. That way I can disconnect it quickly, and since I have the Electromotive stuff mounted on the chassis, I don't have to fuss with any of this when pulling or reinstalling the motor. Weatherpack is nice, but what you get in these systems isn't a connector which can be mounted, and it is a bit harder to pull apart than I would like for something I expected to have to do with some frequency (race motors are like that).
So the result is I can pull the engine by separating one Molex, one crank sensor, and one or three wires at the starter. No backup light, and no speedometer, though. The backup light could easily have a spade connector somewhere down by where it resides, as you will be under there anyway come transmission removal time. And the speedo sensor is separate from the 14 pin harness anyway.
Of course, fancy connectors have a cool look.
I now have the full Electromotive system, with more sensor wires and two wires to every injector. I kind of solved the problems of having to unplug so much stuff by unbolting the throttle bodies from the manifolds (those nuts are pretty easy to get at), and leaving all that plugged in and in place hanging there when the engine is lowered out from under it.
Instead of a transmission ground strap, and especially if you have solid motor mounts, consider making up a ground wire to run from one of the intake valve cover studs to one of the 8mm bolts holding the rear motor mounts in place. Easier to R&R, and harder to forget (especially when dropping the engine/tranny). Nary a problem with this.
When cogitating on these things, keep in mind what will be where when the powertrain gets put back in. I replaced the entire wiring loom with, in most cases, smaller gauge Teflon coated wire (I happened to have quite a lot of that, with various codings). I thought it would be convenient and flexible to use those plastic connector blocks, where you insert a bare wire end and clamp it with a screw. Alas, I located that, and a couple of relays, in a place which seemed great with engine and tranny out. But once the need arose to get in there to do some trouble shooting, it was tough to get at. I should have mounted all that over to one side despite somewhat longer wire runs, to make it more accessible.
Some thought, anyway. For all but the starter relay wire and the alternator to starter wire, just about any connector should have plenty of current carrying capacity. For the Electromotive, you surely will use a relay to connect directly (maybe via a fuse) from the starter main cable to the relay, so the relay coil connector doesn't have to be stout. Probably no heater blower going in?
JJ 911SC 05-29-2014 03:52 AM
If you are running Electromotive, they suggest to keep some of the wiring apart, like the Crank and Cam sensors so they don't get trigger by other signals.
I used the DME plug for the Unswitch 12 volts, Switch 12 volts and Fuel pump. (see Trog post # 60 of http://forums.pelicanparts.com/porsche-911-technical-forum/427451-my-pmo-itb-project-7.html)
I went the other way, one loom per functions. Afer having some problem at the Main 35 pins connector, I decided to do a giant break box for the ECU so all circuit can be monitored live and isolated if required.
http://forums.pelicanparts.com/uploa...1399510741.jpg
http://forums.pelicanparts.com/uploa...1399510787.jpg
Gordo2 05-29-2014 07:41 PM
Great Gouge
Walt,
Great info - really like the tip on the yellow starter relay wire. Seems like the best option and obvious approach, yet it never occurred to me.
Also a great consideration on access to the connections once the engine/trans is installed - been thinking that one over as well.
You are spot on for the engine config (PMO's,bare essentials, no heater blower etc.). Coil packs are mounted on top of the engine with a Clewett coil pack mount as opposed to chassis / firewall mounted. Engine config is posted here:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/785959-gordos-3-2l-engine-rebuild-ready-reassemble-4.html
I never considered the benefit of mounting the coils on the chassis (plug removal for ignition disconnect, DFU remains wired to XDi controller...) but wishing I had. At this point, I've taken that option off the table since I've purchased/installed the coils on the Clewett mount.
I've only been looking at multi-pin connectors that use crimped pins/terminals (I'm not that good at soldering).
I'm also primarily interested in mountable connectors (like the two I've posted). It appears that most multi-pin connectors can't be mounted without fabricating a specialized knock-out panel and I'm not up for that.
Mainly interested in mounting for organization and cable stress / relief options, however I'm not completely opposed to zip tying connectors in the area ahead of the shock tower cross member if it provides an organized and efficient layout.
JJ,
You are out of hand - another option I would have never considered. Very nice work and configuration, but way beyond where I'm willing to go. Appreciate the point out to Trog's thread, I'll check it out.
I hope to settle on an approach and buy the remaining wiring stuff this weekend.
Thanks guys.
JJ 911SC 05-29-2014 07:59 PM
Originally Posted by Gordo2 (Post 8090080)
... I hope to settle on an approach and buy the remaining wiring stuff this weekend...
Gordo,
Take your time. Last year, after installing the Electromotive kit, it was late in the summer but nothing is more satisfying then get her started on the first (or second) cranking.
Bonne Chance
JJ
Gordo2 06-05-2014 08:52 PM
Update and Pin-out plan
I went ahead and bought the Molex XRC 14 pin circular connector as previously pictured. Seems like a nice piece of gear.
Here's the plan for the pin-outs (Electromotive XDi Magnetic Crankshaft Sensor and DFU Coil wiring routed via Molex connector):
http://forums.pelicanparts.com/uploa...1402026556.jpg
Let me know if you see anything whacky here - otherwise I'm moving out on it this weekend.
Thanks,
Gordo
Tbone425 06-05-2014 11:17 PM
Timmy2 just sent me my new custom harness this week... all i can say is....... :-)
JJ 911SC 06-06-2014 05:05 AM
Gordo,
You need to carry across the connector the DFU Shield (pin 16) all the way to the DFU.
Inside every DFU cable, under the gray sleeve, there is a "one way" shield wrap around the wire and the shield wrap itself is wrap with a Bare wire.
Its messy but on both side of your Molex connector you will need to get all 3 bare wires together and use 1 of your spare pin (M or N).
On the DFU side, the shield stop there as close as possible to the connector (the shield is only connected to the ECU).
http://forums.pelicanparts.com/uploa...1402056267.jpg
sjf911 06-06-2014 05:38 AM
Thanks,
Gordo
That looks great, who did you source the connector from?
Gordo2 06-06-2014 05:51 AM
Good Eye
Great Catch JJ,
Missed that one last night as I was focused DFU connector pin-out table, completely overlooking the drawings... Plan updated.
Meanwhile, your point out made me look a bit harder at the shielded cable approach Electromotive is using.
Based on the XDi instructions to extend wires using 16awg, with no mention of shielding - I'm assuming the shielding is really only needed in and around the engine coils and spark plug wires.
I need to draw up the basic schematic as well, but it will include:
I will be extending the DFU wires (via 16awg per instructions) to reach the controller under the passenger seat in the following manner:
- Shorten the DFU shielded connector wires and insert in the Molex engine side connector
- On the chassis side Molex connector I will run (4) 16awg wires (white, red, black and probably another black with 6" of the insulation stripped to ID) to the controlled to complete the DFU connection.
Steve - I picked up the Molex connector from Mouser Electronics. At some point I will add the part #'s to the diagram - its quite a research project otherwise.
Thanks again.
JJ 911SC 06-06-2014 07:43 AM
Originally Posted by Gordo2 (Post 8102475)
... Based on the XDi instructions to extend wires using 16awg, with no mention of shielding - I'm assuming the shielding is really only needed in and around the engine coils and spark plug wires.
I think this could be an option;
No connection throught the Molex, ECU side of the Molex grounded to pin 16 & DFU side of the Molex grounded.
http://forums.pelicanparts.com/uploa...1402065747.jpg
Lapkritis 06-06-2014 09:23 AM
I like this Painless Wiring bulkhead connector for building out engine harnesses:
http://ecx.images-amazon.com/images/...mL._SX300_.jpg
Item #40130
Gordo2 06-06-2014 09:32 AM
Electromotive XDi Wire Harness - Carbs
Here's the wire configuration I went with for the XDi controller multi-pin connector:
http://forums.pelicanparts.com/uploa...1402072025.jpg
Some factory installed wires in the AMPSEAL 23 pin connector were not needed and were removed (MAP sensor etc), and the DFU extension wires were added.
I wrapped the harness in Techflex F6 3/8" sleeving and put some heat shrink on the ends:
http://forums.pelicanparts.com/uploa...1402072203.jpg
Gordo
sjf911 06-06-2014 09:37 AM
Now that's disgustingly simple and uncluttered. :p
Gordo2 06-07-2014 06:57 AM
Receptacle Mounted
Made a mount for the Molex pin connector receptacle (test fitment). Will be wiring it in today:
http://forums.pelicanparts.com/uploa...1402149172.jpg
Gordo
Gordo2 06-08-2014 08:41 PM
Engine Side Connector Wired
I wired up the engine side plug connector this evening - a few photo's to document my progress:
Electromotive Crankshaft Position Sensor
I routed the Electromotive Crankshaft Position Sensor wire(s) around the driver's side engine tin and and back to the connector. The crank sensor wires are bundled in a rugged, shielded insulation - as such, I didn't see any point in wrapping this part of the harness in Techflex sheathing:
http://forums.pelicanparts.com/uploa...1402282495.jpg
I had a bit of an UUUGH :confused: moment as I prepared to attach terminals to the crank sensor wires.
- The Electromotive instructions show the crankshaft sensor wires as a bundled RED, BLACK and BARE wire.
- The XDi controller wire harness included a RED, BLACK and BARE (bundled in a gray, shielded insulation wrap) wire for the crank sensor (very small wires BTW ~ 22 awg)
- Meanwhile my crank sensor wires were WHITE, BLACK and BARE (bundled in a black, shielded insulation wrap):
http://forums.pelicanparts.com/uploa...1402283016.jpg
The crank sensor wire harness came with a pre-installed connector. I probably would have never noticed the color scheme discrepancy if I would have used it. Meanwhile, since I cut the connector off to shorten the wires and connect to my multi-pin connector, I kind of freaked for a bit.
I went ahead terminated the sensor side WHITE wire to the XDi controller side RED wire.
Hopefully it will be OK - I'll give Electromotive or Clewett a call tomorrow about it.
Oil Pressure and Oil Temp Sensor Wires
I similarly ran the oil pressure and temperature wires around the passenger side engine tin. I wrapped these in Techflex:
http://forums.pelicanparts.com/uploa...1402283889.jpg
Interesting note - THAT DAMN OIL TEMPERATURE SENSOR CONNECTOR IS QUITE UNIQUE! I searched all over locally for a spade receiver big enough to fit the terminal but ended up cutting the old one off of the 3.2L harness and spliced it in...
Terminating the Engine Side Molex Connector
I also ran the alternator idiot light (blue wire) to the connector.
Once everything was routed to the connector I added the terminals put them in a long piece of shrink wrap and plugged them into the connector:
http://forums.pelicanparts.com/uploa...1402284295.jpg
Before I hit the shrink wrap with heat (that stuff's difficult to remove...) , I gave it a test fit:
http://forums.pelicanparts.com/uploa...1402284423.jpg
I've mounted the engine harness to a bracket and clamp - but will leave enough slack between the engine and the chassis connector to allow movement/flex. I want to make sure I don't have undue stress on the engine side wire connectors.
If everything works out - it's going to be a pretty clean set up, looking nearly wire free.
Inching along...
Gordo
JJ 911SC 06-09-2014 02:40 AM
Originally Posted by Gordo2 (Post 8106600)
... I had a bit of an UUUGH :confused: moment as I prepared to attach terminals to the crank sensor wires.
Had the same problem when it was time to put my system back without using the connector... Fortunately I had took a photo.
Red to White is correct (was pin A on the connector)
For the 22 awg size, I end up folding the end a few time, twisting it and then crimping it.
Looking good.
Gordo2 06-09-2014 03:13 AM
I'm Obsessing
Yep, I'm quoting myself after waking from a dead sleep this morning - realizing a major flaw in my connection approach:
- I've actually isolated all of the engine harness movement/stress (due to engine torquing, vibrations etc) to the engine side pin connections / back-shell: not good...
(BTW the Molex connector isn't designed for / doesn't use an add-on back-shell protector/grommet since the connectors themselves are sealed).
A better approach would have been to mount the connector 90° offset from how I have it (parallel to the shock tower) and make the engine harness long enough to clamp onto the chassis thereby reducing stresses on the connector.
Hindsight - my harness is cut and I'm not extending it... Meanwhile, I can extend the chassis...
I think I can achieve the same wire stress releif by adding a chassis bracket that extends toward the engine. This would allow me to clamp the harness just beyond the connector.
Hard to describe, will post a pic once I make the bracket.
Yea - I've lost it :rolleyes:
Gordo
JJ 911SC 06-09-2014 04:48 AM
Originally Posted by Gordo2 (Post 8106793)
I think I can achieve the same wire stress releif by adding a chassis bracket that extends toward the engine. This would allow me to clamp the harness just beyond the connector...
That should work.
At the end of the day, this is just a minor time set back!
Gordo2 06-11-2014 09:08 PM
Engine Harness Is Complete
I finished up the engine harness this evening:
As intended, it's "simple and uncluttered", or at least it appears simple... ;)
http://forums.pelicanparts.com/uploa...1402545339.jpg
That's it, exactly how it will look when installed.
http://forums.pelicanparts.com/uploa...1402545441.jpg
I still have a bit of wire work to do on the chassis side, but I did add a support bracket that will allow me to clamp the harness to the chassis to relieve stress on the connector:
http://forums.pelicanparts.com/uploa...1402545566.jpg
JJ - thanks again for the encouragement and wise words of patience.
Gordo
toddu 06-11-2014 09:46 PM
Looks great Gordo!! Get yourself a sound pad, will finish off the look and takes 10 minutes with engine out.
Todd
JJ 911SC 06-12-2014 02:53 AM
Great result.
Next winter during my "Biennial Engine Drop Event" I may borrow your spark plug wire routing idea :)
A foil finish engine sound pad would be a good contrast against the engine.
Gordo2 06-12-2014 03:40 AM
Sound Pad
Thanks guys,
I have the AppBiz foil pad - waiting until I'm done poking around with sharp tools back there to install it.
It's definitely going to make some of the black components stand out.
Hopefully firing the engine off for the first time this weekend - nervous and excited...
Gordo
JJ 911SC 06-12-2014 04:39 AM
Originally Posted by Gordo2 (Post 8112322)
... Hopefully firing the engine off for the first time this weekend - nervous and excited...
Having BTDT, have a helper crank her up and you watch what is going in the engine bay with a fire extinguisher in your hand.
Having had too many cook in the kitchen, I sprung an oil leak from an hand tight oil hose fitting.
Best of luck with the start-up.
timmy2 06-12-2014 11:51 PM
Looks great Gordo, can't wait to see it all installed and running. :)
