turbo on a Standard engine
hello gays
i have a question did any one tried to boost , low boost no more then 0.5 bar
on a standard 3.0 liter engine?
I believe there's a lot of experience over here that can save me a lot of issues
thank you all
where can i get rear tires for wide body i need 245/45 or 40/15
i have looked all over and didnt success to locate them
Old 05-31-2014, 12:56 AM
jsveb's Avatar
The short answer to your question is, yes.
Spend some time searching over on the turbo side of this forum, and you'll find many great examples.
Good luck.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 05-31-2014, 01:28 PM
darnellsgarage
Can only gays answer?
don
Old 06-01-2014, 07:55 AM
porschetub's Avatar
saw that and didn't want to comment ,funny but you might have upset jsveb .
Is it really worth doing this ,surely the compression ratio of the stock N/A motor (somewhat low)would still cause issues without a modern control system (ie expensive )to run it,the 930 motor is built for this afterall???
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 06-02-2014, 02:05 AM
management system
hello to all
my gool will be to use as well angian management system
my question is will the heads and pistons holds to boost.
thanks
Old 06-05-2014, 06:46 AM
Turbonut
Raceboy's Avatar
It will work very well as long as it will not have detonation. With engine management and fully controlled fuel and ignition even higher boost is possible (~0.7-0.8 bars) but eventually you will run into clutch issues.
Of course, intercooler is must-have, but I couldn't imagine ANY turbo project without one...
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 06-05-2014, 09:26 AM
Tadashi Hamaguchi
Hi, I´m not gay but I will leave my comment here )
make sure your cylinders are nikasil instead alusil. normally the nikasil cylinders is used with oem forged pistons. so you would be fine with low boost.
also stay away from dilavar head studs, stick to steel studs!
good luck on the Project!
TH
Old 06-10-2014, 05:49 AM
