rodoredas's Avatar
Engine-Transmission stud 99906103402
hi guys, this part is NLA and I can't find any anywhere, it's the M10 x 67 stud for transmission mount to engine listed in the '83 Katalog, part number 99906103402, any suggestions for alternatives?
cheers
Shane
Shane
1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500
1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158
Old 06-12-2014, 04:50 AM
Walt Fricke's Avatar
Well, I went to my local Porsche junkyard, as I needed all of these studs. Didn't find enough, but got one which was longer. As long as you use a nut, and it isn't too much longer, it should work. Of course, if you don't have such a junkyard about five miles from where you live, you need plan B.
Maryland Metric and other fastener sellers ought to have what you want or something suitable.
As I recall,at least one of these cannot be fastened by a bolt, because the structure of the transmission will prevent inserting it. But it should be possible for the two others. And the one through the starter is a bolt anyway.
Old 06-12-2014, 11:09 PM
rodoredas's Avatar
Thanks Walt,
I found a new set at Patrick Motor Sport, their part number reference is PART # PKG 915 930 G50 SBH ECS, Brian the guy I was emailing was very helpful.
cheers
Shane
Shane
Old 06-13-2014, 02:45 AM
