It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Can I install the intra cylinder sheet metal after cam towers installed??
I need to sandblast and paint the cooling tin. Can I continue with the head and cam tower install and put the tin on afterward? Will it slide in?? Thanks.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 06-21-2014, 12:24 PM
911 2.2 T targa
No, you will need to wait
Before you install the camtowers you need to put in the oil return pipes. The pipes will be blocking the tin that needs to go in from the bottom side.
Old 06-21-2014, 01:40 PM
It's a trap...
Not what I wanted to hear, but thank you for the heads up. Have to go blast and paint cooling tin...drats.
Old 06-21-2014, 02:27 PM
Not unless you are.........
If you are using the one-piece oil return tubes (OEM), you have to wait. However, if you are using the collapsible two-piece tubes, you could proceed with the heads and cam towers installation.
Tony
Old 06-21-2014, 04:49 PM
Try not, Do or Do not
Henry Schmidt's Avatar
There is a third option. Supertec 906 style cooling tin can be installed after the oil return tubes are in place.
At this point there is now great reason to use them but if a mistake happens, they are the remedy.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-21-2014, 08:13 PM
It's a trap...
Thank you, all. I blasted mine this morning and a getting ready to paint. Two day delay. Hmmmm.
Old 06-22-2014, 09:36 AM
