Motor install
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 04-10-2015, 05:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #221 (permalink)
Just need to tidy up loose ends
Tom Feeney
1970 911 T
1973 911 T
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #222 (permalink)
Just need to wire the distributor, install fuel lines and plug in the loose wires. Headers won't be here until next week so I am trying to decide if I should put the old ones on and run them for the break in period.
Tom Feeney
1970 911 T
1973 911 T
Old 04-10-2015, 05:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #223 (permalink)
michael lang's Avatar
just out of curiosity, why did you not finish the reassembly before putting it back in your car? I would think it would be easier for access to everything vs. having reach in and feel your through everything and crawling around on your garage floor.
Mike
'89 CARRERA
#402
Old 04-11-2015, 12:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #224 (permalink)
What do you mean by finishing the assembly? What else should have I put on it?
The reason the alternator wasn't on is it needs to be wired, carbs because I have always had clearance issues with the carbs on because I usually can't get the car high enough and the coil can't go on until the alternator is on.
Otherwise the motor was pretty much together. If you think I should have at least had the carbs on you are 100% correct, if I thought the car was high enough it certainly would have made it easier. I just remember the last time that I didn't have the car high enough and had to pull them off to get the motor under the car.
Tom Feeney
1970 911 T
1973 911 T
Old 04-11-2015, 05:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #225 (permalink)
Funny how it took 3 hours to remove the engine and 7 hours to put it back in.
Tom Feeney
1970 911 T
1973 911 T
Old 04-11-2015, 05:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #226 (permalink)
non-whiner
mreid's Avatar
Don't you love how that works! Seems the time space continuum becomes warped on reentry.
Great job all around!
"Too much is just enough."
Old 04-11-2015, 05:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #227 (permalink)
Gravity is your friend when you pull the engine and your enemy when you install it!
Tom Feeney
1970 911 T
1973 911 T
Old 04-11-2015, 06:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #228 (permalink)
You just answered my question. I figured it might be as much as a clearance issue but wasn't 100% certain. You could have always gone with something like this
Those blocks combined with my jack stands gave me this this height at the rear bumper
I haven't gotten to re installation yet, I can't wait for that adventure
Mike
'89 CARRERA
#402
Old 04-11-2015, 06:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #229 (permalink)
toddu's Avatar
Midrise lift and a hydraulic table = 30 minute job. :-)
Todd
'81 SC
Old 04-11-2015, 06:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #230 (permalink)
Headers are here!
Now if I can just find the Delo SAE 30 oil I will be ready to start it up!
Tom Feeney
1970 911 T
1973 911 T
Old 04-17-2015, 04:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #231 (permalink)
Filled it with oil tonight. I was really expecting a flood of oil to come pouring out of the bottom but not a drop!
Tomorrow night exhaust and start up.
Tom Feeney
1970 911 T
1973 911 T
Old 04-18-2015, 05:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #232 (permalink)
non-whiner
mreid's Avatar
The three milestones of engine rebuilding:
1. Installation - exciting
2. First Start - nerve racking
3. First Drive - exhilarating
Old 04-18-2015, 06:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #233 (permalink)
I am super nervous about the start up.
Tom Feeney
1970 911 T
1973 911 T
Old 04-19-2015, 04:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #234 (permalink)
UnRegistered User
billybek's Avatar
The squeeze at the back door is super tight when firing a new overhaul for the first time...
Good luck and post a video (of the engine, not the back door)!
Bill K.
Old 04-19-2015, 05:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #235 (permalink)
non-whiner
mreid's Avatar
Completely understandable! Particularly considering you have to run it at a higher rpm for 20 minutes to break in the cam/rockers.
The good news is that you will have super hearing the first few times you drive it!
Old 04-19-2015, 07:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #236 (permalink)
Fire it up!
Well, fired it up tonight.
Cranked right up without hesitation and ran smoothly for its 20 minute break in period.
Not a single drop of oil and no funny noises!
Drained the oil and hardly a spec of anything in the oil!
https://youtu.be/rOlBurkiRMg
Tom Feeney
1970 911 T
1973 911 T
Old 04-19-2015, 02:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #237 (permalink)
Now the big question.
I ran Delo SAE 30 for the break in period.
Do I change it o 20/50 now?
Tom Feeney
1970 911 T
1973 911 T
Old 04-19-2015, 02:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #238 (permalink)
911 tweaks's Avatar
YES...especially simce u have run the break in which I would of used the Joe Gibbs Break in Oil but too late for that now...so going fwd use joe gibbs driven driven 15/50 = their DT50 as it has the hi zinc level...I use ONLY JB oils for ALL of my clients and my cars...period... not a spokesperson but NO other oil has this correct additive pkg on the market...recommended by LN Engr & jake rabey & others...hope your rebuild is what u hoped for...bob )))
I live for 911 tweaks...
Old 04-19-2015, 03:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #239 (permalink)
Is that synthetic oil?
Tom Feeney
1970 911 T
1973 911 T
Old 04-19-2015, 04:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #240 (permalink)
