Bagged
So, I went out and purchased one of those expensive engine bags to protect it and keep it clean.
I think Hefty makes them 😉
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
Nice tread and good job !!!
1992 C2 964 (Nevada USA & France)
Back at it
Well, finally getting back to it. Head studs came in yesterday and a new Wrightwood head gasket set is on order. I heard too much bad stuff about other gaskets and want to do all I can to avoid leaks.
These head studs are a work of art! ![]()
Project Addicted
Great thread!!!!!!!!!
Keep up the good work and the updates coming. Love the high value engine bag :-)
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
ARP Head Studs
Well, today the head studs went in. Look at a lot of links on installing them and decided to use a dab of locktite on them. Make sure that you don't overdo it, just a dab near the bottom of the threads will distribute it evenly.
Because of the thread chaser I made (see earlier post) the studs went right in by hand right to the bottom of the hole. Once the Locktite was on I screwed them in all the way to the bottom and then backed them out about 1/4 turn so that they weren't sitting on the bottom of the hole. Once in I used my caliper to make sure they were all fairly even which they were. Just a small turn her and there. ![]() ![]() Gasket set should be here Monday so look for piston and cylinder install next week. Still need to send the heads and cam tower for rebuilding.
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 Last edited by Amstaff; 01-24-2015 at 07:07 AM.. |
Locktite
For some reason the picture didn't post
Important!
One important thing that I should have posted before locktiting the stud in.
TRIAL FIT THE CYLINDERS AND HEADS TO MAKE SURE THAT THE STUDS PROTRUDE ENOUGH TO GET WASHERS AND NUTS ON! ![]()
Nice job !!
Thanks for sharing........ |
Great thread!
Thanks for this great thread. I'm now a subscriber. Just picked up my new project a week or so ago. Yup, broken head studs. This thread will be an invaluable tool for my future endeavors! Keep up the great posts and pics!
Subbed. Awesome thread!
Great read and reference for those of us considering an engine rebuild someday! Thanks!
1971 Light Ivory 911T - Gretchen - sold Looking for Engine # 6114097 2010 Cayman |
Heads and cam towers are boxed and ready for pickup by FedEx tomorrow. I sent them to Ollies. Called and spoke to them today, they said box them all up, put a note in the box explaining what I want done along with contact information and they would call once they get everything and can unpack and examine what I have.
Gasket set should be here tomorrow so I am inching closer to finishing!
Cylinder holders
Saw cylinder holder tools available but when you only use it once why buy expensive tools? I bought a 2 foot piece of 1/2" PVC and made my own. Cut it with my pipe cutting tool to 1 1/2" and it fit perfect.
Parts will be back from Ollies tomorrow so look for updates soon.
I thought you couldn't hone alusil cylinders??
Honing Cylinders
Technically I didn't hone mine. After doing a lot of research I decided to clean them, and then use scotch bright on them. If you search this site you will see a lot of different ways to scuff the cylinders to reuse them. Mine was a low mileage engine and honestly, I didn't have $4000+ to sink into new Pistons and Cylinders so I reused what I had.
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 Last edited by Amstaff; 02-23-2015 at 10:36 AM.. |
I have a 3.0sc with 100,000 on it and I'm wondering what I'm gonna do when I cross that bridge because honestly I don't have $4000 for new ones either. It seems crazy that one piston and one cylinder has to cost $500 or $600 dollars.
For a lot of Porsche guys money is no option. To me it is and I can't just drop 20 grand to build a killer motor so I am building mine on a budget. Honestly I don't have a budget but I am buying parts as I can afford it. I took a 3 month break over the holidays but am back at it. I think all of the big expenses are behind me now.
Had I tried to save the money to buy new Pistons and cylinders along with the extra cash it would have taken for additional machine shop work it would have been a 3 year build.
Parts are here!
Heads and cam towers got here today!
Cylinder install
Got the block ready to receive the piston and cylinder
