Vol 1-2 exerpt needed
Ive seen a number of descriptions but would like to see the original page from vol 1-2 , 65-71 that gives the factory instructions for torquing the rod bolts. Can anyone post for educational purposes?
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
How's this?
![]() andy |
Thanks! That gets me measured, oiled and rod bolts torqued to 36.2 ft/lb. I'd also like to see the bit about 90° -+ 2°? The only place I've seen it in print is page 200 in Wayne's book, at the very top of the torque specifications.
I need to get my hands on Vol 1-2 for some light reading.
The 15 ft#/ 90 degrees is for the turbo and the Carrera, 3.2 and carries into the C2.
Bruce |
I have now from above (thanks, Andy), the specification to torque the rod bolts to 36.2 ft/lb from the workshop manual 65-71. Then, my Vol 3 doesn't seem to have rod nut torque instructions or values. So, the factory spec, 36.2 ft/lb extends through the years covered by Vol 3, I assume. And, I have instructions in Wayne's book with different parameters and what appears to be no differentiation between engines. The Bentley manuals only go back to 1978...
Then, I look in the parts catalog and see my 72-73 MY rod bolts (914-103-171-00-M260) are also use on 911/911S / Carrera (1974-1977) and 911SC / Turbo (1978-1983) (SC) which places them firmly in the realm of the turbo and Carrera. So, I have several methods to choose from: Bentley and Wayne say the 20nm/90° method with Wayne suggesting threadlocker. Bruce A's book says a range 37-40.5 ft.lbs. with moly lube and motor oil. The factory spec of 36.2 ft/lb on oiled threads in workshop manual Vol. 1-2. Wayne cites a discussion here about this in post #12 while researching his book that may discuss the pros and cons of each method. I haven't been able to find it. I don't want to reinvent the wheel here. I've got a lot riding on not screwing up my build. I don't want to start another rod bolt stretch vs torque discussion. I don't think there's a stretch specification for the OEM bolts. I just want to arrive at the best procedure for tightening these dang nuts. If I don't come to some logical conclusion, my OCD will force me to assume every bump in the road is a rod coming loose from the crank.
my 74 spec book which is the same crank and rods shows 5 to 5.5 mkp which 5 converts to 36.7 ft#
3.2 to 3.6 uses thinner rodbolts Bruce |
