dmj dmj is offline
dmj's Avatar
Is starter working?
I just rebuilt my engine using your books and wanted to test the starter before I put the engine and transmission back in the car.
I jumpstarted the starter attached to the engine using my battery and starter cables, and the starter operates but the engine does not turn.
I tested to remove the starter and jump started it again on my workbench. The motor is running and the gear is turning, but the gear does not extend.. so I assume that is why it does not engage with the flywheel teeth.
Is it a problem with the starter or is it just the way i jumpstart it? I grounded it and connected the + cable to the terminal closest to the starter, not the battery connection that usually is connected which require the ignition switch.
I have. 911 SC 1980.
Best,
Daniel
Daniel Alsén
Porsche Club Sweden
1980 911 SC
2013 Land Rover Discovery
Old 06-30-2014, 01:26 PM
Air Medal or two
afterburn 549's Avatar
Did you jump the relay?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 06-30-2014, 02:08 PM
dmj dmj is offline
dmj's Avatar
No.
There are two major terminals, the battery + connector and the one close to the starter connected to the field winding with a strap. Also, we have the flat connectors to the ignition switch (top) and the cold start injector (bottom).
I connected the battery + to the terminal connected directly to the starter field winding, bypassing the relay.
Is there another (proper) way to jump it?
Old 06-30-2014, 11:37 PM
Air Medal or two
your relay is there to pull then bendix out to the teeth on the flywheel.
bypassing that -your starter will just spin freely
Old 07-01-2014, 10:54 AM
dmj dmj is offline
dmj's Avatar
Many thanks, works great now.
Old 07-19-2014, 07:35 AM
Solenoid........
You meant solenoid instead of relay?
Tony
Old 07-19-2014, 01:25 PM
