Torque supertec nuts
I have just installed the camshaft housing on my 2.7 with supertec headstuds.
Went off to the shop to buy a 14mm 1/2" 12point socket, came home and it doesn't fit.
Interference with the housing...
So what do you guys use, 3/8" with a universal socket joint and then to the torque tool? A flexible joint?
Old 10-09-2014, 12:01 PM
safe's Avatar
1/4" 12 point socket. or it might have been a 3/8...
Magnus
Old 10-09-2014, 01:36 PM
DSPTurtle's Avatar
A 3/8" 14mm 12 point works like a charm. You can get a thin wall. I don't remember needing a flex joint with the set of Supertec studs I did earlier this year. A 1/4" will work, but you may have to special order a 14mm in 1/4".
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 10-09-2014, 03:06 PM
3/8" did it without a flex joint, I had one of those desperate moments there hehe
I got a friend to drive to his garage and pick up all the 3/8" parts he had late in the evening.
Old 10-09-2014, 03:38 PM
