What cams should I use in my 911 2.4 with 2.2S pistons?
The title says it all: What cams should I use in my 911 2.4 with 2.2S pistons?
Here is some facts:
- 7R case (will have the oil bypass mod done)
- 3.2 oil pump
- 2.2S pistons
- Twin plugged 2.7S heads (35/35 ports and new I46 E40 valves)
- ARP rod bolts
- Carrera tensioners
- 40IDTP Webers (will most likely be replaced with 40IDA Webers)
I now that the calculated compression will be somewhere around 10.4:1, but with twin plug, 98 octane fuel and the right cams this should be OK.
I have considered the following cams: E, Solex, DC30, S, DC40 (Mod-S) or DC44. I want the impossible: huge low end torque and screaming top end power somewhere around 7000-7500 revs
It will be a streetcar that only occasionally sees a track – maybe once or twice a year. I want to be able to cruise around town without having to shift gears all the time, but I do like revs on the open roads as well – so I need a balanced compromise between low end torque and top end power.
Greetings from Sweden
Mikael
Old 11-05-2014, 11:54 AM
tharbert's Avatar
I've heard good things about Mod Solex grind (DC40?). I would have gone that way had I put my hands on some good cores for a regrind. I decided to go with E to check my slide down the slippery slope.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-05-2014, 12:04 PM
I am quite sure that:
DC30 = Mod-Solex
DC40 = Mod-S
Old 11-05-2014, 12:29 PM
cams?
I would go solex or softer. S on smaller motors is pretty puny down low then wait, wait for it then woooooooo. best
Old 11-05-2014, 01:30 PM
