| Registered Join Date: Sep 2012 Location: Nevada and France
				 |  Fan Housing compatibility  SC 1982
			Hello ! I had to replace my Fan Housing. Number is : 930.106.102.0R for 245 mm. SC 1982 Can i put 930.106.102.3R, 930.106.102.4R or 901.106.101.5R ? Thanks ! Nicholas year # fan blades fan diam (mm) fan P/N shroud P/N shroud casting type shroud casting # shroud depth (1) (mm) Alterntor Current (amps) alternator length (2) (mm) comment crank pulley diam (mm) fan pulley diam (mm) 1965-66 11 250 901.106.101.03 901.106.101.03 sand cast Al 901.106.101.03 86 35 114 no coil studs 110 95 1965-66 11 250 901.106.101.03 901.106.101.04 sand cast Mg 901.106.101.0R 86 35 114 no coil studs 110 95 1967 11 245 901.106.010.03 901.106.011.00 sand cast Mg 901.106.101.0R 86 35 114 no coil studs 110 95 1967-68 11 245 901.106.010.03 901.106.011.00 die cast Mg 901.106.101.0R 86 55 114 no coil studs 110 95 1969-74 11 245 901.106.010.03 901.106.011.00 die cast Mg 901.106.101.5R 86 55 114 with coil studs 110 95 1975-77 3.0 Turbo 11 245 930.106.012.00 911.106.008.00 die cast Mg 901.106.101.5R 95 70 123 with coil studs 130 83 1975-77 5 245 901.106.011.00 911.106.008.00 die cast Mg 901.106.101.5R 95 70 123 with coil studs 130 83 1978-79 11 226 930-106.011.01 930.016.005.00 die cast Mg 930.106.101.0R 95 75 123 with coil studs 130 80 1980-83 11 245 930.106.012.00 930.105.006.00 die cast Mg 930.106.102.0R 95 75 123 with coil studs 120 83 1978-89 3.3 Turbo 11 245 930.106.012.00 930.105.006.00 die cast Mg 930.106.102.0R 95 75 123 with coil studs 120 83 1984-86 11 245 930.106.006.07 930.106.102.07 die cast Mg 930.106.102.3R 106 90 137 with coil stud hole 120 83 1987-89 11 245 930.106.006.07 930.106.006.07 die cast Mg 930.106.102.4R 106 90 137 with coil stud hole 120 83 | ||
|  06-11-2013, 12:20 AM |
| Registered Join Date: Oct 2008 Location: Nash County, NC.
			Not knowing the numbers because the paper work is not available the answer is 19mm thickness of the back where the alternator rests and bolts to.  It started with the 1975 model year for the 901 part #.  The 78/79 housing is too small for the fan but then the 80 to 83 SC will do your need. Bruce | ||
|  06-11-2013, 06:35 AM |
			ok thank for your answer. It's quite complicated beacause there is a lot of 245 mm on sells offer and i do not know the compatibility annonce | ||
|  06-11-2013, 07:16 AM |
			you have a PM Bruce | ||
|  06-11-2013, 05:41 PM |
| Registered Join Date: Jan 2004 Location: CT
			Here is a summary of the various fan/shroud/alternator combinations
				__________________ Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process | ||
|  06-11-2013, 07:16 PM |
			Thank you tom ! With your post, i understand taht i can only take the 1980 - 83 SC or 78 - 89 3.3 turbo because de shroud casting are differents Last edited by iiXii; 06-12-2013 at 03:11 AM.. | ||
|  06-12-2013, 12:37 AM |
			You can use the earlier '75-'77 shroud. It has the correct alternator depth. You can also use a '67-'74 shroud if you have the alternator mount face machined 9 mm deeper to allow for the larger alternator.
|  06-12-2013, 03:50 AM |
|  06-12-2013, 07:10 AM |
| Registered | Quote:
 If you would also use the fan, you would have to think about the pulleys.
				__________________ Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. | ||
|  06-12-2013, 09:11 AM |
|  06-12-2013, 11:59 AM |
|  06-12-2013, 12:04 PM |
			part 901.XXXXXXXXXXXXX are in fact not compatible
|  07-11-2013, 09:09 AM |
| Registered | Quote:
 I have a cracked 83 SC shroud with alternator and a complete 71 E shroud with motorola. Since the alternator / recess specs don't match (discovered by trial fitting....school fees) I was thinking of swapping them with alternators attached. After searching and reading about 5 different threads on VRs - that went right over my grade 9 electronics head - I found this answer. Brilliant. Thank you.
				__________________ Don't buy a Porsche until you can afford two. 1980 SC - sold 1983 SC - sold 2000 C4 - sold 1967 912.5 in DIY build | ||
|  12-02-2014, 11:34 AM |
| Registered Join Date: May 2004 Location: Boulder, Colorado
			iiXii - So what's the problem?  If it is the surface corrosion, you can clean that up.  It's not going to affect the performance of the fan. The usual reason to replace housings is that they have a big crack somewhere. Often in one of the three blade-like parts which holds the center housing to which the alternator attaches. Is that a crack on the boss which holds one of the bolts for the ignition coil plate? If so, I'd think that could be fixed. | ||
|  12-02-2014, 11:53 PM |
