Driver's License Owner
The Watson's Avatar
Various fittings: re-use, refurb or replace?
Rebuild on a 2.7. What is standard protocol for the following pieces when doing a full rebuild?
oil temp sender
oil pressure relief spring and piston
oil pressure sender
oil tank level sending unit
Also, for the oil temp and pressure, are there double-pole senders so as to signal a gauge and a warning light for the same thing?
Thanks and HNY!
Chuck
Thanks -- Chuck
1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700
Old 12-31-2014, 06:57 AM
The 2.7 has 2 OP senders, one for the light, one for the instrument. Change the former, and use the OE one. Failure of the sender for the instrument is rare. The temp sender is a reusable item, as is the level sender in the tank. Might want to change the gasket for that, but it's probably not necessary. If the OP spring and piston work smoothly in the bore, I leave 'em alone.
The Cap'n
Old 12-31-2014, 07:05 AM
Walt Fricke's Avatar
me too
OP idiot sender is pain to replace w/engine (and CIS) in car, and prone to leak eventually. OP senders will wear out, bot easy to replace if it happens and don"t leak. OT has no moving parts, so should last forever, and also easy ro change.
Old 01-01-2015, 08:11 PM
The Watson's Avatar
Thanks Walt & Cap'n.....just the real world info I needed.
Thanks -- Chuck
Old 01-02-2015, 05:13 AM
